jandsaudio Posted March 27, 2013 Report Share Posted March 27, 2013 Ok so my wife comes in this morning after getting off third shift and wakes me up at the asscrack of dawn, I mean its like 430 in the morning. She said on her way home her HU made a popping noise almost as if a CD was stuck in it(face plate foods down and cd goes in behind it). Kept hearing a this thud behind me, where she has 2 12's under the seat. Noticed that only one of the subs was going in and out real slow almost like it was getting a constant power for some reason. Now keep in mind, the truck is off and the HU is off. I took the radio out and switched the RCAs channels to opposite sides and then it followed it over to the other sub. I ended up having to disconnect the amp from the battery via the power wire. I can't get to the actual amp because its underneath the backseat and the seats bolted down and is solid as a 10 ton brick shithouse. The amp would have to be on for it to come out of the subs wouldnt it or am I wrong on that? i unplugged rcas completely from the back of the HU and it stopped also, didnt know if that would help any since I know its not getting any signal through those. Was wondering if anybody has any suggestions? Thanks guys! Link to comment Share on other sites More sharing options...
Bradprobert Posted March 27, 2013 Report Share Posted March 27, 2013 Have you tried a different head unit to see if the head unit was the problem? [sharedmedia=garage:vehicles:2223] 4th-order under rear seat build log: http://www.stevemeadedesigns.com/board/topic/165708-4th-order-under-rear-seat-chevy-extended-cab/#entry2410477 SD, thank for the input. I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . Link to comment Share on other sites More sharing options...
jandsaudio Posted March 27, 2013 Author Report Share Posted March 27, 2013 Well I would but the person that had the truck before me didnt use a harness connector and just cut the ends off the factory wiring.... Jackasses! I'll try that here soon and see what happens Link to comment Share on other sites More sharing options...
Bradprobert Posted March 27, 2013 Report Share Posted March 27, 2013 I bet that's gonna be fun to do lol if its not the radio, then the next thing I would check is your wiring to power the head unit. It would probably be best to do that first to check for shorts. [sharedmedia=garage:vehicles:2223] 4th-order under rear seat build log: http://www.stevemeadedesigns.com/board/topic/165708-4th-order-under-rear-seat-chevy-extended-cab/#entry2410477 SD, thank for the input. I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . Link to comment Share on other sites More sharing options...
