Omega5002 Posted March 29, 2013 Report Posted March 29, 2013 You wire to a capacitor like how you would wire to a battery though I hope you're not using the cap to help with poor electrical. does make a cool volt meter though Yeah, but when you have shit electrical, it hurts the electrical even more, it's like putting a bandaid on a 1 inch deep cut 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
Omega5002 Posted March 29, 2013 Report Posted March 29, 2013 You wire to a capacitor like how you would wire to a battery though I hope you're not using the cap to help with poor electrical. does make a cool volt meter though Yeah, but when you have shit electrical, it hurts the electrical even more, it's like putting a bandaid on a 1 inch deep cut band aids are for wussies. i use c16 racing fuel super glue and duct tape Goddamn it Ghost, that's not the pont 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
BrettAlthoff Posted March 29, 2013 Author Report Posted March 29, 2013 should i do the big three rather then the cap? how does one know if the electrical is crap? i used to be running at 400 watts rms with a soundstream amp and then that hit the fan.. so i upgraded too this this 1300 watt at 2 ohm amp.. and the capicator has no 0 gauge hook up and has a resistor im supposed to wire in with it? 2000 oldsmobile alero (2) rockford fosgates 4x6's (2) rockford fosgates 6x9's (1) hifonics zrx2000.10 (2) re adudio se-x d2 12" big three
BrettAlthoff Posted March 29, 2013 Author Report Posted March 29, 2013 and at the 400 watt rms nothing dimmed unless the car wasnt running but just in on position and then it would just dim the radio light a little and the console one 2000 oldsmobile alero (2) rockford fosgates 4x6's (2) rockford fosgates 6x9's (1) hifonics zrx2000.10 (2) re adudio se-x d2 12" big three
BrettAlthoff Posted March 29, 2013 Author Report Posted March 29, 2013 my buddy asured me that the cap was the way to go sense i wasnt running that much power,, is the big three really going to be that much more beneficial then just adding the capacitor? or is there any way to tell how my electric stuff will handle in my car...? concerned that i have gone the wrong route in what im going to be installing.. any input would be greatly appreciated.. 2000 oldsmobile alero (2) rockford fosgates 4x6's (2) rockford fosgates 6x9's (1) hifonics zrx2000.10 (2) re adudio se-x d2 12" big three
SkarredSierra Posted April 7, 2013 Report Posted April 7, 2013 doing the big 3 in zero gauge never hurts tho. and when you hook up your amp do not ground it to the cap. you have to ground it seperate. the resistor is not installed with the cap. you just use that to charge it. as far as wiring goes on your subs try going to the12volt.com they have wiring diagrams on there. ive used caps alot in lower watt systems and they always seem to work ok. but alot of people trash on them. while i will say that extra batteries are alot better the cap is an ok cheaper alternative for anything around 1000 rms. i would get another battery or power cell before to much longer tho just to be safe.
