ramdisknet Posted April 5, 2013 Report Share Posted April 5, 2013 Hello! I have just built a dual 21" sub box with 2 separate chambers and 1 23" long port per sub.. What would you recommend length wise for them? Here are the specs.. PRODUCT SPECIFICATIONS Power Handling (RMS) 1000 Watts Power Handling (max) 2,000 Watts Impedance 8 ohms Frequency Response 24 to 1,700 Hz Sensitivity 107 dB 1W/1m Voice Coil Diameter 4" Magnet Weight 250 oz. THIELE-SMALL PARAMETERS Resonant Frequency (Fs) 22.4 Hz DC Resistance (Re) 6.3 ohms Mechanical Q (Qms) 2.60 Electromagnetic Q (Qes) 0.38 Total Q (Qts) 0.33 Compliance Equivalent Volume (Vas) 24.85 ft.³ Maximum Linear Excursion (Xmax) 9 mm Surface Area of Cone (Sd) 1706 cm² MATERIALS OF CONSTRUCTION Cone Material Paper Surround Material Cloth Voice Coil Wire Material Aluminum Basket / Frame Material Cast Aluminum Magnet Material Ferrite MOUNTING INFORMATION Overall Outside Diameter 21.80" Baffle Cutout Diameter 20.20" Depth 10.20" # Mounting Holes 8 Please Help! D: Link to comment Share on other sites More sharing options...
SnowDrifter Posted April 5, 2013 Report Share Posted April 5, 2013 Length is dependent on port area and box volume to get a desired tuning frequency. If you already got the box, why do you need to know port length? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
ramdisknet Posted April 5, 2013 Author Report Share Posted April 5, 2013 The lows aren't sounding too great... The ports heights are 3 and half inches high and 23 wide and the port length is currently 17" long.. Should I shorten them? I can with a router as the box is quite big.. 22" depth 30" high and 50" wide.. Link to comment Share on other sites More sharing options...
SnowDrifter Posted April 5, 2013 Report Share Posted April 5, 2013 Can you give some detailed box specs? Outer dimensions Wood thickness Any bracing Port height Port width Port length And pics of the box itself, and how it's positioned in your vehicle ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Nate Futuristic Posted April 5, 2013 Report Share Posted April 5, 2013 you dont have enough port area and shorting the port length will raise tuning... time to build a new box down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies Link to comment Share on other sites More sharing options...
ramdisknet Posted April 5, 2013 Author Report Share Posted April 5, 2013 I did put in the title box that it is a PA sub box so a vehicle isn't involved... Link to comment Share on other sites More sharing options...
