KWP369 Posted February 12, 2008 Author Report Posted February 12, 2008 (edited) id browse the classifieds and see if theres anything there, as it looks like your looking for 2ohm stability you may be able to find a deal. well i have 2 10" audiobahn AW100T specs are as follows power handlin-500rms freuency response-26Hz-1kHz efficiency-92.8dB voice coil is 2" Single 4 Ohm operation-4 Ohm so after using the rockford amp wire wizard it'll be wired down to 2 ohms, and power handlin is 500rms and i have two so thats why i'm lookin for an amp that does 900-1100rms @2ohms... Edited February 12, 2008 by KWP369 Quote Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs
roscoe1129 Posted February 12, 2008 Report Posted February 12, 2008 Audiobahn a1600v not a great amp but cheap and you will see about 1100 easy from it. Quote Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
