Lifted2000Ford4x4 Posted May 20, 2013 Report Posted May 20, 2013 ima do it in the morning i only have one door panel made but i want to hear it before i copy it for the other side hope it goes well for you!
jmsonoma03 Posted May 20, 2013 Report Posted May 20, 2013 do you know where the factory amp is? you need to get both hi lows and connect them to the front and rear inputs going into the factory amp once again white wires are left ch and grey is right ch !! then connect the harness that you say you have for the speaker outputs to your new amp!!
ThreehundredC Posted May 20, 2013 Author Report Posted May 20, 2013 alright it seems to simple to be so confused ill get on that in the morning
ThreehundredC Posted May 20, 2013 Author Report Posted May 20, 2013 well went and pulled the 2 white wires from the connection on the driver side and put them to the passenger side positive negative..got no sound so signal for highs but bass when i plug only one rca in then it cuts low when i plug the second one in what are the rear speaker colors i tapped the green with brown line and yellow with a greyish stripe it said yellow and green but didnt see that wore so i went with the other yellow wire dont think that is it
ThreehundredC Posted May 21, 2013 Author Report Posted May 21, 2013 so i found that i have to tap before the amp in the front but im not gunna bother with it im either doing a 7 inch tablet with equalizer or a single din no screen dvd player stashed somewhere and then to a big screen in the dash
