mav1989 Posted April 14, 2013 Report Posted April 14, 2013 So I am looking at grabbing 4x Crescendo PWX 6.5s and 2x Crescendo FT1 Super Tweeters to replace my factory 6 speaker system. I can do simple math: 4x 150w rms =600 2x 80w rms = 160 Total 760 So I probably need something between 600 and 800 watts @ 4 ohms. Something I never really understood though is how many channels you need to support 6 speakers and how you wire them. Can any one enlighten me? Or if this has been explained well else where point me in the right direction? Thanks!
tyma1026 Posted April 14, 2013 Report Posted April 14, 2013 6. stick the things in the holes. aim right and dont hurt it.
tyma1026 Posted April 14, 2013 Report Posted April 14, 2013 just kidding. :devil: 6 channels. I'm sure you can find a wiring diagram somewhere on the net to help you
Pasta Prime Posted April 14, 2013 Report Posted April 14, 2013 Here is a simple calculator to use to figure out what you will need. http://www.the12volt.com/caraudio/boxcalcs.asp or http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=4&I=41 New build coming........ YouTube:http://www.youtube.c...6?feature=guide Old Build Log: http://www.stevemead...d-on-the-cheap/ Old Screen name: Redrebel66
mav1989 Posted April 14, 2013 Author Report Posted April 14, 2013 any recommended 6 channel amps. There dont appear to be too many out there. Sonic eletronics only sells 1.
mav1989 Posted April 14, 2013 Author Report Posted April 14, 2013 maybe it would just be better to get a 600 watt 4 channel and a 160 watt 2 channel? if thats the case then i need to figure out how to hook up 3 amps.
Pasta Prime Posted April 14, 2013 Report Posted April 14, 2013 You could run a 4 channel. the 6.5's to two channels and the tweets to the other two. Just keep your ohm load safe for what ever amp you get. New build coming........ YouTube:http://www.youtube.c...6?feature=guide Old Build Log: http://www.stevemead...d-on-the-cheap/ Old Screen name: Redrebel66
