Think I fried my headunit
So I've been really eeger to re wire my whole system, and my alternator went last week and my battery has a bad cell in it. So what I've been doing(Very stupid) is hook up jumper cables from my car to the other with the accessories on so I can get some power in my car. I did all of my wiring, radio was running perfect, system was perfect, and then when I took out my battery to go get it tested I got home and did the same thing, but this time my radio didn't turn on. I checked the power wire behind it and there's power going through it and I checked all my grounds/fuses and it's all good. So could I have fried my HU from leeching my power? Possibly lack of voltage that strained it?
sounds fishy. Take your deck out with the wires, hook up the yellow (batt) red (turn on) straight to your battery on the positive and hook your ground up to your negative on your batt. and that will tell you if your head unit powers on or not.
-playing with different setups
Do what ccm said first but yes you could reuse the vehicle harness
Car: 2000 Ford Focus 4 door
HU: Kenwood KDC-X395
Front Highs: stock
Back Mids: Stock
Subs: Skar VVX-12 ( 1.79 f3 tuned to 32 hz)
Amp:Audiopipe APSM 1500 mini
Wiring: KnuKoncepts Kolossus 4awg
You should be able to as long as its the same size radio ex: single din or double din
Front Highs: stock
Back Mids: Stock
  • Who's Online   0 Members, 0 Anonymous, 991 Guests (See full list)
