Scion XB RS2 Wall Install Build
You said you're running all hybrid mids/highs... Is that hybrid audio technologies? And what amps are gonna be used for the subs?
Ad also what is the sq inch of port area per foot? Looks great man i bet it sounds good too :)
FosgateLife,
I have not puchased the hybrid yet. The hybrids i am going to use are here http://hybrid-audio.com/legatiase/
The amp I have running on the subs hasn't been mounted to the amp rack yet. The amp is actually under the passenger seat in my XB for time being.
Im using an old school PPI amp from 1998. PPI PC 2350 which is 1400RMS (more like 1500-1600rms).
The RE AUDIO SR PRO 12's call for 1.5cf of air space per sub for optimal performance. The box was build for 3.0cf per sub which was 12cf with (4) 7.5" ports that are 4" in diameter. The box was tuned at 34hz.
We tested the XB with the sealed box I had in the car with (2) kicker 15s before all this construction. The car was hitting the hardest at 44hz but at 44hz, i couldn't play music like I wanted, so the next best hz was at 34hz.
It has bass that is LOW, sounds like a freight train from a distance. I'm very impressed with it overall.
I finally got the amp moved from under the passengers seat to its new home, the amp rack.
I'm going to change that black vinyl. It's hard to make it stick even with tac90... I may just go with black felt. That is what I used on the headliner.
Since I have a wall now, i thought I would make use of a 7" monitor. I was going to put it where I took out the passenger air bag on the dash, but have since changed my mind. So....I started on modding the center dash bezel. I took out the mini storage box along with the lighter and ashtray.
Here are some pics of different stages for it.
Almost there. few more areas to touch up. Once the piece is finalized, I will be scuffing up the upper portion of the green area to repaint. The bottom part of the bezel, from about where the top of the monitor will be at will be painted black all the way down to the bottom. Reason being, is the bezel will be hydrodripped in black skulls. By painting the bottom black, the skulls on the green part will blend into solid black on the bottom. Heres a pic of a remote control back done this way.
I will post more pics when completed of the final product.
Well I made some changes on the build. 1st, I don't know if the 4 subs (RE AUDIO SR PRO) were defects or what, but the same day i installed them one of the coils went. So that left me with 3 subs. When my new one arrived and it was replaced, a week later the tensils on 3 of the subs broke loose. So the wholesaler was gracious enough to
allow me to upgade and pay the wholesale difference to SE PROs which handle 2x the power of the SR PRO.
2nd, I ripped the black vinyl off the wall. I replaced it with the same black felt I used on the headliner. Made a world of difference in looks.
Looking good... surprised you had to take the seats out for that... have around 12 cuft behind the sear easily to play with...
Thanks for the compliment...
I wanted the wall to be flush with the C pillars. You can't keep the factory back seat setup as it is and achieve that goal i wanted.
And even flush i barely got a 12 CF box.
With the 1/2" mdf trim piece on the back of the box in the hatch, the box is almost flush with the top of the car and has about 4" from the bottom of the box to the bottom of the hatch...
Looks good, i like how it all flows together to the amp rack. Gonna have to show my buddy this build, he has an xb as well
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
Thanks so very much. I haven't done this all by myself.....The guys down at the car audio shop (Distinct Beat) have been so very helpful to me with this build, with their assistance, shop use & advice. I proudly support this wonderful business.
