Box suggestions for a 10" Type X
Enzo
OP, you mentioned Type X in your first post. Another member on here posted information regarding a Sundown X Series sub. Im more inclined to believe that you have an Alpine Type X. So for clarification, what sub DO YOU have? Also, what voice coil configuration is this subwoofer? How do you have it wired up to the amp, as well as voice coils configured? Who built the box the sub is in now? A sealed box is pretty easy stuff partner.
The sub i have currently is the ALpine Type X 1042d. Its wired to 2ohms. Its weird because any song with low notes hits pretty decent but any song that has highs, its like you can barley hear them. Also its weird because when the lows hit my voltage doesnt drop alot, but when the highs hit the voltage drops a ton yet no boom high sound is coming out.
Where did your box come from? Is it COMPLETELY sealed? Any air leak in a sealed box will cause serious output issues.
Yes its completely sealed and im not sure it came with the sub when i bought it
im trying to post pictures of the box but i cant figure out how too
I am checking the recommended dimensions for the Alpine. I was assuming it was Sundown. OK, I think we are still good here. Alpine recommends 36 hz tuning for the 10" sub and a volume of 1 cube (net) if ported. You are at roughly 1.2 cubes net right now, with the displacement of the pvc itself you should be pretty much good to go I think.
Yes 3" inner diameter pvc. You can look up the outer diameter online or you can measure it. I would probably look it up as I can read more accurately than I measure lol. Cut the hole to the outer diameter but be careful not to cut too large of a hole or you will have a hard time sealing it lol. You will want to use some sort of sealant anyway once you get the port in. Seal both the inside and the outside of the box around your pvc.
The optimal sealed box for that sub is .49 cubes (net) so the same concerns apply as when I thought it was a Sundown sub. Seems like your box is just too big which I think would likely be most of your issue.
2006 Scion xB
2 Sundown SA12D2
Ported at 32hz
147 on non termlab (140-142 on TL)
Currently in a walled 4th @ 50hz (not metered yet)
Hifonics brz2100
Alpine Type-S Components
Kicker 300.2
Big 3 / Skyhigh 1/0 cca
Optima Blue Top
3 e8s ported at 32hz
135.1 sealed on dash @ 56hz
135.0 outlaw (I must have chosen song poorly lol)
Build log
'Brandon15zzz', on 09 May 2012 - 3:13 PM, said:snapback.png
May have been clipping but none fucks were givin.
To post a picture create a photobucket account and upload to it, Then you can attach the picture from photobucket to here.
2006 Scion xB
2 Sundown SA12D2
Ported at 32hz
Hifonics brz2100
Kicker 300.2
Optima Blue Top
Build log
Sorry everyone for late post! Ive been busy with school alot and just finished on friday! I am uploading the pictures of the box now :)
Heres a few pictures of how the sub is setup in my trunk so you guys can get an idea on how it looks and which side to do the port on. null_zps25e9ddad.jpg
Heres some pics of the box itself with amp on it
  • Who's Online   0 Members, 0 Anonymous, 611 Guests (See full list)
