Guest reestblazer
You could open up the amp and see if anything is toasted in it
yeah i guess i could, i never had the amp more then 1/2 gain, and my subs hardly had n e excursion
Guest reestblazer
any more opinions?
Guest reestblazer
anyone else know anything else?
if anyone finds out anything please let me know
well its def the amp if it smoked, open it up and look for soot if you dont have a warranty anymore
sounds like too low of ohms, burnt mosfets (likely), have you pulled the subs out cause a wire could have come loose
anything really could have happened but let me say smoke of anysort is a sign to stop, unplug everything and investigate the problem befor you blow ur subs (which u did)..... hence why it sounds like the amp crapped out
either way the amp sounds like likely source
send it to dealer/manufacturer/db-r electronics.... whichever applies
