Guest reestblazer Posted February 14, 2008 Report Posted February 14, 2008 guys please help me, my amp keeps making my subs make kind of a thump sound and it keeps going then it starts smoking a tiny bit and puts off a aweful smell, whats the matter with it? any idea? Quote
mrwigglezdj Posted February 14, 2008 Report Posted February 14, 2008 what amp. what subs and what ohm load are you running and do you have proper power and ground connections, is voltage droping way low (12 volt and lower?) Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
Guest reestblazer Posted February 14, 2008 Report Posted February 14, 2008 what amp. what subs and what ohm load are you runningand do you have proper power and ground connections, is voltage droping way low (12 volt and lower?) massive audio 3000.1 , 4 dd 2515's d4's , running 2 ohms, with a kinetik 2400 to amp, never drops below 12v, and yes proper power and ground Quote
Aaron813 Posted February 14, 2008 Report Posted February 14, 2008 Could be that you might need to ground the headunit better and the rcas in the rear Quote
Guest reestblazer Posted February 14, 2008 Report Posted February 14, 2008 Could be that you might need to ground the headunit better and the rcas in the rear it started smoking, amp still shows perfect power and all, and my subs thump but u can still hear a lil bass, could my amp be fried? Quote
Aaron813 Posted February 14, 2008 Report Posted February 14, 2008 You could have started to toast a coil on one of the subs Quote
Guest reestblazer Posted February 14, 2008 Report Posted February 14, 2008 You could have started to toast a coil on one of the subs nothing seemed wrong with the subs completely at all, i saw the smoke coming outta the vents on the amp Quote
Guest reestblazer Posted February 14, 2008 Report Posted February 14, 2008 nothing seemed wrong with the subs completely at all, i saw the smoke coming outta the vents on the amp anyone help? Quote
jizzybizzy Posted February 14, 2008 Report Posted February 14, 2008 nothing seemed wrong with the subs completely at all, i saw the smoke coming outta the vents on the amp thats what happened right before my subs blew. Quote you ain't been bizzy til you've been wit jizzy. Vehicle:: 2005 Saturn Ion Headunit:: Jensen 9312HD Speakers:: RE SE Coaxials Subwoofer(s):: (2) 15" RE SEs Amplifier(s):: Audiopipe AP1500.1D Audiopipe AP1504 Enclosure:: Sealed Wire: KNU KONCEPTZ 1/0 Battery:: Kinetik HC600
Aaron813 Posted February 14, 2008 Report Posted February 14, 2008 You could open up the amp and see if anything is toasted in it Quote
