Hey guys this is my first build since I was about 17. Keep in mind that this is a budget build, and will be upgrading as funds are available. So try not to laugh at some of the equipment as it is not all the very best but enough to get me started. Thanks in advance to anyone who took the time to view my UBL, if you liked it or not, thank you!
Sub enclosure I made over a weekend. I believe it is tuned around 40-50hz 1.75 Cubic feet of air space.
RE Audio 6.5C Component System.
After I put the enclosure in and built a panel for the mids and highs amp.
Solidered all the power cables.
Ground cable.
12" Kicker CVR's
Thank you for taking the time to view my UBL, and a special thanks to the entire SMD forum community for making this all possible by inspiring me to do my own build.
UPDATE!
I ordered a digital volt meter/gauge and will be putting it in this front panel along with a USB charger plugin and my remote gain knob. It was moded with fiberglass resin jelly and some thin aluminum, then plasti dipped.
UBL (Uninterrupted Build Log) - CLICK HERE
# Deck: KDC-BT555U #
# Amp - Mids/High: PPI MOS-50 #
# Amp - Subs: Hifonics 1100.1D #
# Wire: 4awg 120Amp Fuse #
# F - Mid/High: RE Audio RE6.5C #
# R - Mid/High: RE Audio RE5x7FR #
# Subs: 2x12" Kicker CVR #
Nice build man. I have a 02 spectra an had 2-12" obsidians an a BC2k in it
2008 Yukon 2-18"s EVILS
TEAM SSA
TEAM AUDIOTEX
Thanks man, I am working on getting a video up as soon as weather permits, was snowing today in Michigan...
no bare boxes in SOTM
NoFearX18 said:
Fixing this and will enter next month if I don't have it done soon, thanks for the heads up on that.
Small Update!
I built a relay with fuse and diode protection and boxed it. Ended up having some labels made for it too, here are some pic's!
SPECS
Will run up to 14 Devices @ 3.0amp on each lead.
Fuse protected.
Diode protected relay.
This is the Device Relay DR100A or so I call it.
I will be installing this in the next day or so, have the perfect spot on my amp rack.
  • Who's Online   0 Members, 0 Anonymous, 18282 Guests (See full list)
