Ithertz84 Posted April 27, 2013 Author Report Posted April 27, 2013 i have question if you do all your installs yourself why not do it yourself ?I never hook up 2 amps to 2 subs. I always had 1 big amp for both subsSorry, but on this part. You've hooked up two subs to one amp and your saying it's more difficult to wire one sub up to one amp twice? I find the opposite to be harder.Oh didn't know. I was gonna clamp them together, or I could do each amp to each sub,Are your two amps strappable? If they're I'd do that because gain matching both amps to each other is more work then having them strapped and tuning just the master amp because slave will use same settings as master when strapped.Yea there strappable. See the company gonna set all my gains with O-scope b4 they ship them to me because I know owner really good. So all I have to do is wire it up, ok I know imma run 2 runs for power an ground them both in back an for my my wires run to my speaker do I hook them up +,+ an -,-? An the amps will be at 1ohm self bridge able? Or I have to wire the subs up at certain way in box to make amps 1 ohm, I'm buy dual 2 subs, to make @1 ohm daily
Aidan Hansen Posted April 27, 2013 Report Posted April 27, 2013 If strapped you will only be able to do 2ohm load or .5ohm load. See diagrams below: http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22#results If you want 1ohm load your going to have to change subs to d1 if your strapping the amps. See diagram below: http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=12#results ^Vehicle log to come soon for this.^
Ithertz84 Posted April 27, 2013 Author Report Posted April 27, 2013 If strapped you will only be able to do 2ohm load or .5ohm load. See diagrams below: http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22#results If you want 1ohm load your going to have to change subs to d1 if your strapping the amps. See diagram below: http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=12#results Ohh ok ill do 1 ohm subs(aint bought subs yet) that's y I do research 1st b4 I buy. I can take getting made fun of but at least I get help an answer like I did thanks a lot,
Aidan Hansen Posted April 27, 2013 Report Posted April 27, 2013 Glad to help. Anymore there's allot of making fun of people especially on forums but that makes you a better person I think because you learn how to take it and not let others piss you off easily. Whether you're on the forums, or in real life situations. ^Vehicle log to come soon for this.^
Ithertz84 Posted April 27, 2013 Author Report Posted April 27, 2013 Glad to help. Anymore there's allot of making fun of people especially on forums but that makes you a better person I think because you learn how to take it and not let others piss you off easily. Whether you're on the forums, or in real life situations. Yea I'm easy get along wit nearly impossible make me mad, anyways do I wire my 2 dual 1 subs like this, To my amps make it 1 ohm load strapped? (sent from iPhone) http://www.youtube.com/watch?v=3tMr4OQnki8(If u on CPU)
Ithertz84 Posted April 27, 2013 Author Report Posted April 27, 2013 If strapped you will only be able to do 2ohm load or .5ohm load. See diagrams below: http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22#results If you want 1ohm load your going to have to change subs to d1 if your strapping the amps. See diagram below: http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=12#results Can't open up thread to see how to wire my 2 dual 1 subs but ill do research an see so I know now
Aidan Hansen Posted April 27, 2013 Report Posted April 27, 2013 Yes, with your amps running in a d1 load you will be taking the positives from your master amp and putting them into the positives on one side of each sub and the slave amps positive wires will go into one side of the subs negatives and then on the other side of both subs you will have one wire go from one sides positive to the negative on the other side like the diagram I posted earlier. ^Vehicle log to come soon for this.^
Jessica Posted April 27, 2013 Report Posted April 27, 2013 Also, the company making your amps can't set your gains for you unless maybe you are shipping your headunit to them. Gain is set according to what signal it is receiving. Ao if have to find at where your headunit maxes out while still giving a clean signal and adjust your gain to match. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Aidan Hansen Posted April 27, 2013 Report Posted April 27, 2013 heres pictures then. ^^ This is the one i'm talking about. Thanks Kranny. ^Vehicle log to come soon for this.^
