So im starting a new build for the truck, I plan to do 4 15"s I dont know what kind yet... I just cant decide if i want it to be sealed or vented. Im not making a wall, and plan to do it with fiberglass. im used to making sealed enclosures and listening to them slam!! i have not made to many vented ones nor am i a fan of them, mainly cause around here i havent herd of any good ones.
So the questions comes, should i make it sealed or ported?
What do you think is better overall?
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
Ported boxs just are louder and you can tune them better. What kind of music do you listen to?
are ported louder? i listen to a bit of everything, mainly rap in the truck but every now and then rock but mainly rap with some deeeeep bass. ive never really tuned one i supose thats why they never turned out great, i want somethen that will be loud and hit really deeeep.
In Dash
Rear Flip Down
most of the time ported boxes are louder. If you can build one and tune it properly, I think it will outperform a sealed box. what ind of subs are you planning on running?
Edited by 01xtreme
My System:
Pioneer AVH-P3200BT
4-Dayton 7 inch reference series (front doors)
8-Onkyo 3/4 inch tweeters (dash)
1-Sundown Audio 100.4D (mids/highs)
2-18" BTL's (for now)
Crescendo 3kwp (for sale)
Complete rebuild coming soon...
It most deffintally should by far outperform a sealed box is built and designed well
um i think im going to go with kicker cvx's.
In Dash
Rear Flip Down
well i got time to build one i think i can tune it good if i can figure out what it is suposed to be at. i wanna stay away from a wall build, and i will be having many curves on the box. so i dont know how i would go about putting a vent in it, maby in the back facing up?
In Dash
Rear Flip Down
if i make a box dose it matter where i put the vents? dose it matter if all 4 subs are in 1 chamber or in 4 diffrent chambers with there own vents? what would be a good cu ft size for them, and how big of a vent?
In Dash
Rear Flip Down
All four subs can be in he same chamber it doesn't effect anything. As far as port/sub placement, usually subs and port on the same plane works well OR you can do a CRX style which is where the subs are on the top and the port facing the rear. Box/port size differs from sub to sub. What Are you using???
i want to use kicker cvx 15s can i do the port on top, with the subs kinda on a 45 degree angle?
In Dash
Rear Flip Down
