Recommended electrical for this system?
I am currently running a AQ 2200 at .5 ohm on a stock 150 amp alt and a d1200 battery and a new battery under d hood
My amp gets hot at times and I believe it may be my electrical not being strong enough to support it.
I had a lighter volt meter and it showed no voltage drop and my voltage stayed above 14 at all times..
So I assume that the meter is inaccurate and I must be dropping voltage.
What electrical (batteries, alternator) would you recommend for this 3000 watt system?
i ran a sundown 3k at 0.5 with 2 batts and a 270xp amp. it was plenty happy !
you with 1 bat, stock alt. i doubt you're staying at 14 at 0.5. thats alot of strain in the alt....
i recommend. biggest alt you can fit in your car. better safe. you'll most likly want a bigger amp later on in life so why not start saving...
and 2 agm batts.
lol full tilt dropping to like 11.6
good luck with not smoking the amp at that voltage and ohm load.
edit: where did you get 3000 watts from, when you have a 2200rms amp?
AQ are underrated amps and he probably just rounded up the rms power lol
I think ami clamped over 3k out of 1 @ 0.7, I don't think people think about box rise sometimes. Ami's was nominal I believe. Most people think that 0.5 will give them same results.
My build
98 s10 2.2
3 american bass HD 15s with psi soft parts. (on there way here)
atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build)
alpine 6.5s in doors
infinty 4x6s in dash.
clarion cz201 HU.
mechman 240a H/O alt
stuff i still need.
SHCA 2/0 wire
SHCA 1/0 to 2/0 adapters
Atomic AT-3000.1
Lots of sound deadner
new mids an highs, still debating on what to do.
A few Deka g31 batts.
i know getting an alt soon. Amps under rated and wired .5 ohm puts off around 3k
To be honest. Unless that is nominal or u have very little box rise you are not getting 3k out of that amp. You are probably getting about 1500 at most out of that amp with your voltage drop, mayb even less power.
My build
98 s10 2.2
clarion cz201 HU.
stuff i still need.
SHCA 2/0 wire
Atomic AT-3000.1
well can voltage dropping that much cause the amp to clip easier? because the coil cooks easily on a 2k rms hdc4 im assuming the amp is clipping causing that
  • Who's Online   0 Members, 0 Anonymous, 2967 Guests (See full list)
