cheebs Posted May 2, 2013 Report Posted May 2, 2013 i have two vxx 15s running off a mb onx1.1500. but i have been thinking about getting a bigger amp. i was looking at a friends aq2200. i do understand from what i read that 500 to 700 watts won't make a difference i can hear. but would it be easier on the elecetrical to run the aq2200 with the gain turned lower than higher on the MB?
Swordlordboy1234 Posted May 2, 2013 Report Posted May 2, 2013 Brands such as my quart and those other "cheaper" brands are known for drawing more power and making more heat for the rated power... He'll... A 2200 from SQ might put out its full 2200 rms with less drop then your seeing with your 1500 because of efficiency and quality of the product My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
Lifted2000Ford4x4 Posted May 22, 2013 Report Posted May 22, 2013 sword is right. the AQ is a good amp, but make sure you still have the electrical to support it. big 3, H/O alt, extra batts.
