Some help please..3000 watts
alenv10
I will post a pic up. I threw it all in yesterday just for a comp so its coming back out and done the right way. Stock 160 alt for the ford and i drop to 13.5 at 1200 rpms at full tilt.
2005 ford explorer xlt limited 4x4
2 xs power d3400s
2 runs of shca
mid/ highs- infinity 6x8 3 ways
2 18 ssa icons
2 aq 1200.1 @ 2 ohms
10 cubes tuned to 36 hrz
you drop to 13.5 at full tilt on a stock alt?? running 2400wrms?
thats what happens when you have box rise. 1 ohm turns into 4 ohms.
I know it looks like ghost customs but it was just for the comp so i didnt care about cleaning it up. Im replacing the speaker wire with some shca 8ga. Again this was for a wknd install not staying like this.
2 xs power d3400s
2 runs of shca
2 18 ssa icons
+ to + to subs on master, + to - on subs on slave, jumper from- to- from master to slave
2 xs power d3400s
2 runs of shca
2 18 ssa icons
okay when i get to that point of strapping i will ask for help, but very nice, what kind of reducers are those? 4awg to 0? look nice, what brand
NOTHING DOWN HERE YET :(
OBSIDIAN FTW
lol for the guy who bashed hifonics.. you will definitely get rated wattage at rated voltage... they are built CEA compliant which means that you will indeed get XXXX watts if you provide XXXX volts as advertised. You should not expect a lot more than rated though. Read up on it and you will see that although hifonics is not top of the line, you do get what they advertise. I believe their newer amps all are, but some of their older ones may not be. Here is a link about CEA compliance.
http://www.cea2006.com/cea2006.htm
Now I am not saying that a 3kw hifonics will put out as much power as a 3k DC (actually 3.5k dc but you get the idea) ... I am saying that a 3kw hifonics will put out 3k.
2006 Scion xB
2 Sundown SA12D2
Ported at 32hz
147 on non termlab (140-142 on TL)
Currently in a walled 4th @ 50hz (not metered yet)
Hifonics brz2100
Alpine Type-S Components
Kicker 300.2
Big 3 / Skyhigh 1/0 cca
Optima Blue Top
3 e8s ported at 32hz
135.1 sealed on dash @ 56hz
135.0 outlaw (I must have chosen song poorly lol)
Build log
'Brandon15zzz', on 09 May 2012 - 3:13 PM, said:snapback.png
May have been clipping but none fucks were givin.
No problem. And yeah i used toolmakers 1/0 to 4ga reducers. I have shca 1/0 cca so i just went with the alum. Ones rather than spend the extra for copper. They seem to work great.
2 xs power d3400s
2 runs of shca
2 18 ssa icons
i'd still rather have an amp that is rated for 3k but really does 4k, over a 3k amp that needs to see a constant 14.4v to get 3k out of it.
  • Who's Online   0 Members, 0 Anonymous, 1861 Guests (See full list)
