soundqubed hdc3 15 box design?
ZachG
Hey so I need some help on a ported box design for a soundqubed 15 3.0 coil.
The max dimensions are Width 16, Height 21 max, Length 30-36.
It will be going on the back seat of a 97 dodge Dakota ext cab. Mostly mainstream rap is listened to. It will be ran off a soundqubed 1200.1
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
Here is a suggestion for the HDC3 15", simplest to build box:
Enclosure Specifications:
Fb = 35 Hz
Vb = 4.4 ft^3
External Height = 21 in
External Width = 36.25 in
External Depth = 16.5 in
Port Width = 4 5/8 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 36 1/4 x 16 1/2
Left & Right Sides = 15 x 18 3/4
Front & Back = 36 1/4 x 18 3/4
L Port Internal Assembly Parts:
Top to Bottom = 14 1/8 x 15
Extension = 4 1/2 x 15
Assembly guide (generic dimensions):
Important notes:
- The port needs 4 5/8" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
Fb = 35 Hz
Vb = 4.4 ft^3
Cut Sheet List:
Important notes:
Looks really good thanks man. I'll be sure to post pictures of finished project.
I'm guessing the braces are 1" wooden dowels?
  • Who's Online   0 Members, 0 Anonymous, 1681 Guests (See full list)
