I need to put a battery or 2 in my trunk to run my 2 MTX 7801's. The question is How do i wire a battery if its going to be in the trunk?
18's in a wall to come....Its not all about the posts....check the member #...
Grab some 1/0ga cable and put + to + and - to ground
Then run the + to the back of the alt and eureka
so you dont have to wire the amps to the batterys in back? b/c i see alot of people doing that. why is that done?
Well yea you do wire the batt. to the amp, but you gotta keep the battery charged.
ok thanks man.  I always wondered that. I guess you just run the amps to the positive terminal just like the starting battery. thanks man.
Not exactly the amps to the battery, you need the battery hooked to the alternator to have the battery charged
if you dont do anything with the stock wiring then dont worry about the alt....unless u plan on doing the big 3 upgrade...oh and make sure u fuse within 18" of the front battery
i likes me some audio stuff...
  • Who's Online   0 Members, 0 Anonymous, 1289 Guests (See full list)
