Xplay75 Posted May 15, 2013 Report Share Posted May 15, 2013 I have 2 kicker 12 comps and id like to have then facing front with port front to seal it of,max 37x39x17 the amp I'm running is a jl 500.1 also have big 3 upgrade to Link to comment Share on other sites More sharing options...
Xplay75 Posted May 15, 2013 Author Report Share Posted May 15, 2013 Joe x can u help out the subs are 4 ohm forgot to state that above Link to comment Share on other sites More sharing options...
Joe X Posted May 15, 2013 Report Share Posted May 15, 2013 Here is a suggestion, any changes let me know, the c124s are rated only 150W so be a bit careful with the 500.1: Enclosure Specifications:Fb = 35 HzVb = 4 ft^3External Height = 17 inExternal Width = 38.75 inExternal Depth = 15.5 inPort Width = 3 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:Front = 35 x 15 1/2Back = 38 3/4 x 15 1/2Left & Right Sides:Side 1 = 14 x 15 1/2Side 2 = 14 3/4 x 15 1/2Top & Bottom = 38 3/4 x 15 1/2L Port Internal Assembly Parts:Front to Back = 11 x 15 1/2Extension = 3 x 15 1/2 Assembly guide (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All boxes built outside the car need to fit in their way in not just have the right dimensions.- This box should be operated around subwoofer(s) rated power. If that´s not the case, let me know.- The port needs 3" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 32 Hz is suggested. Link to comment Share on other sites More sharing options...
Xplay75 Posted May 16, 2013 Author Report Share Posted May 16, 2013 Thank you I had one of the comps in a sealed box and it was surprising it took some power the max on the comps I have is 500 as the manual says and my amps rated power at 2 ohm is 500 so I should be ok Link to comment Share on other sites More sharing options...
