Here is everything i have installed then ill. Share my problems.
2-12"pioneer dvc ts-w3002d4's
1-boss blx 5000 2 channel
Pioneer deck-DEH-8400BH
Pioneer DEQ-7200 audio processor
Pioneer 6x9's -rear deck
Pioneer 6.5's -doors and 3/4" pioneers in doors
Power wire is 2/0 ground is same size also have a 3 fared cap and have done the big 3 upgrade
Inline fuse 100amp. At battery and d block with 2-100 amp fuses
Now my problem is i have my subs wired. To the amp at 1 ohm multi meter says1.4 ohms the amp is 1 ohm stable in bridged mode but wen i turn the volume up the fuse blows sometumes at the d blocck sometimes under the hood ????? Can anyone tell me wut iam doing wrong please????
Pics would help...
Also, ditch the amp, ditch the capacitor...
2007 Volvo S40 2.4i (no turbo :( )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
Pics would help...
ya i figured the amp wasnt to good and so no cap?also is the 2/0 to big for my power wire?
it isn't stable at 1 ohm bridged. that's your problem
ok i misunderstood the specs on the amp ill wire them in at 2 ohms then or 4?
You have to check the wiring on the subs to even see if they are 2 or 4 ohm stable.
Yes ditch the cap because they are eye candy, and put more stress on the electrical system including the amp.
2/0 is very good, it just depends on the brand and OFC or CCA
Your problem might also be that you have 2/0 wire fused with 200amps, should be 400 amps as long as its under 20'.
To be honest i dont think the brand of the 2/0 power wire is to good. Wen i bought it. I. Didnt know. Half of the little bit i know now after countless hours i spend daily researchin car audio tryin to take in everything i can i jus went and got wit the thought that bigger power wire was wut i wad after not once did the thought of. The brand cross my mind but i feel dumb now cuz common sence should of told me to get a good quality so ill be replacin it in the next few days along wit inline fuse and d block and as far as my cap its in the storage closet i took ir out soon as. Fosgatelife said to ditch it i am stuck wit my sorry boss amp fo a while but will be replacin that soon as possiable
Kranny is right. Look at this page in your amps manual:
http://www.manualslib.com/manual/218019/Boss-Audio-Systems-Blx3500m.html?page=12#manual
It says bridged mode goes 2-8ohms while non bridged goes from 1-4ohms. IMO running them unbridged at 2 ohms will be your best bet if you want to keep the equipment you've already got. Wiring diagram is shown below for 2ohm operation on each sub:
Don't run bridged unless you want to bridge at 4 ohm and wire your subs like this:
Chevelle%20Team%20Cover%20without%20RE%2
^Vehicle log to come soon for this.^
Not sure wut ofc or cca is ???
Read here:
http://www.caraudio.com/forums/wiring-electrical-installation-help/518955-difference-between-ofc-cca.html
  • Who's Online   0 Members, 0 Anonymous, 243 Guests (See full list)
