i think i found the reason why i am not getting the volts is b/c i never replaced the factory wire comeing from alternator to fuse box do ya'll think that is the problem i just ran a 4ga wire from battery to alternator??????
yea that prolly had sumthin to do with it
but i still think u should be gettin more voltage from that big of an alt
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
i know it i REALLY do not think that was the problem i thought it was but it wasn't
so can anyone help me pleaseeeeeeeeeeee
do you think it is b/c they are made to have a load on them that is why it is low when i put it right into drive????
and after driveing my car when i shut it off my batts should be around like 13.5???? or so b/c after driveing it and shuting it off my batts are at 12.81 why is that or is that normal???
everything is normal, ur alt turns on when u need power
if you are at a stop light, with no music playing and no accesories on, ur engine might sound like its dieing then revving up, this is normal
and might be moreso when u have more batts to supply and store energy
my car is 12.8 off, and 13.5 when bumping at 2000 rpm, ~14 at idle
so is the bass on ur eq all the way down?
it should be at 0.... maybe that will help
u should have 0 gauge from alt to batt also
