i am going to bed tho good night talk to ya'll tommorrow
dueces.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
If I was in your shoes I would sell all 4 subs and the box and start off fresh! I think 2 15's would work out nicely in there.
that is what i am gunna do if the ebay aucion does not work out like i want i am just gunna trade this guy
the 4 15 's in the box for
2 15 L7's /clarion in-dash dvd tv/and a kenwood cd player
i already got a kenwood tv but i need another for my girls truck b/c i sold hers when times got rough a few months ago
ONCE I SEND MY AMP OFF TO GET FIXED CAN I RUN MY 4 DUAL 4 OHM L5 15'S AT 1 OHM WITH THIS AMP AND WOULD IT HURT THE AMP TO RUN 1 OHM FOR A DAILY??????
HERE IS THE SPECS FOR THE AMP
Class D Monoblock Subwoofer Amplifier
RMS Power Rating:
4 ohms: 1250 watts x 1 chan.
2 ohms: 2500 watts x 1 chan.
1 ohm: 5000 watts x 1 chan.
Remote Bass Control
Hi-Level Input
RCA Low Level Input/Output
Subsonic Filter
Crossover Control
CEA-2006 Compliant
12, 10, or 8 gauge power/ground leads
Dimensions: 27 1/2"L x 9 5/8"W x 2 1/8"H
Amplifier Specifications:
Amplifier Class D
Number of Channels 1 - Mono
RMS Power (4 ohms) 1250 watts x 1 channel
RMS Power (2 ohms) 2500 watts x 1 channel
RMS Power (1 ohm) 5000 watts x 1 channel
Bridged RMS Power N/A
Peak Power Output N/A
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged N/A
THD at Rated RMS Power 1%
Speaker Level Inputs Yes
Preamp Outputs Yes - 1 pair
Built-in Crossover Low-pass (LP)
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 50 - 200 Hz
Subsonic Filter 0 - 25 Hz
Signal-to-Noise Ratio 95 dB
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled No
Fuse Rating 300A x 1
Dude you have the ZX2500.1? I dont think that amp drops down to one ohm and if it does you wont be able to use your 4 dual 4 ohm subs to get the right ohm. you can use only 2 of them to get the one ohm. Thats only if the amp drops down to one ohm which i dont think it does, but hey i could be wrong.
hey can someone please help me with wireing my subs here is what i got
4 dual 4ohm 15's with 4 wires comeing out of box
i am trying to get them too 2 ohm
what fucks me up is the dots on the post
someone told me to make 2 ohm with 4 dual 4 ohm subs is
put one wire to the + to + and then - to - and then run a + off the + with the dot and then a - off the - with a dot for all 4 subs and then tie them all together +'s with +'s and then -'s with -'s am i correct???? someone please help me
nall bro you need to wire each sub in series which each sub would be playing at 8 ohm, parallel all the + and - to the amp and you'll see that final 2 ohm load man. look on www.rockfordfosgate.com and play with the woofer wizard man.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
well i just got my amp back today went out there and hooked it up with out any speakers hooked to it and pop it blew up and started smokeing baddddddddddddddddddddd everything was hooked up correctly so i called kicker and they are paying for it to get shipped back to them and then they are gunna fix it or give me a new one so now i have to wait another week or so
