Valentin93 Posted May 19, 2013 Report Posted May 19, 2013 Hey guys, I wanna build a setup for my buddy's birthday, it will be the last time i'll see him in a long while, he is going to the army I wanna install two SWR-10D4 (10' Alpine Type R 1000 Watt RMs woofers wired @ 1 ohm into a ZRX2000.1D) into his little 2005 Honda Accord. Could someone please help me with the design?? I know he likes rap music mostly so I figured a ported box would be nice here are the specs of his trunk: Trunk opening 17.5" H 33.5" W Inside the trunk 18.5" H 34.5" W and 21" D I can assemble it inside the car if it'll be bigger that the opening. Please SMD forum help me!!! Have a good day, Valentin.
Joe X Posted May 19, 2013 Report Posted May 19, 2013 Here is a suggestion: Enclosure Specifications:Fb = 35 HzVb = 2.6 ft^3External Height = 16 inExternal Width = 33 inExternal Depth = 18 inPort Width = 2 1/2 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2x Front = 15 1/4 x 14 1/2Back = 33 x 14 1/2Left & Right Sides: 16 1/2 x 14 1/2Top & Bottom = 33 x 18Shared Port Internal Assembly Parts:2 x Front to Back = 15 1/4 x 14 1/22 x Extension = 5 5/8 x 14 1/2 Assembly guide (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All boxes built outside the vehicle need to fit in their way in not just have the right dimensions.- The port needs 2 1/2" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested.
Valentin93 Posted May 19, 2013 Author Report Posted May 19, 2013 WOW!!! This looks amazing! Yes I would like the 45s all of them, Thank you very much sir!
Joe X Posted May 20, 2013 Report Posted May 20, 2013 You're welcome, the 45s inside the port are only to be done if they can be done right or they will hurt instead of helping, their size has to be selected in a way that the width at the turn stays 1/2 of the port width at the center duct to each side, take a look:
