amps are wired to 0.7 5k from each amp? really that much?
5k total is what he means. And that's if you're lucky. Wired at .7 is still pretty high to expect 2.5 from each. But maybe because you're running 14v you might clamp that much. Only you can tell us, no one will know for sure because not every set up is the same.
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
Ratings :
2500 @ 1 ohm
1200 @ 2 ohms
600 @ 4 ohms
Testing :
Wired @ 1 ohm in Derrick's Explorer :
1690 Watts
21.4 Amps
78.97 Volts
3.69 ohms Actual
Wired @ 0.25 in Derrick's Explorer:
3360 Watts
63 Amps
53 Volts
0.85 ohm actual
Around 14v actual voltag
clamp tests from a 2500. should do more than rated as it is, so should both should have been be doing over 2.5k with my 12v batteries??
  • Who's Online   0 Members, 0 Anonymous, 1707 Guests (See full list)
