Benjamin Amparo Posted May 19, 2013 Report Posted May 19, 2013 i need some help on getting a sub amp and im on a tight budget of 150 (could go a little higher if need be). currently i have 2 alpine type e 250 watts rms each but will probably get something new in the future but nothing crazy. so im looking to have between 600 and 750 watts rms at 2 ohms. any suggestions would be appreciated thanks 97 Lexus ES 300 Source: clarion cs702 Front stage: faital pro 6fe200, seas prestige 27tafnc/g Subs: soundqubed hds212 x2 Amp: mids and highs PPI P900.4. subs Alpine MRP-M850
Lifted2000Ford4x4 Posted May 20, 2013 Report Posted May 20, 2013 check sonicelectronicx.com for amps, look for amps that are CEA 2006 compliant to make sure they do rated power, then go to amazon and see if you can find it there cheaper... try a Belva BB2000D it does 900rms at 2 ohms, you can always set the gain down a bit to keep from blowing the subs. for 169.99 its a decent amp for a decent price.
Benjamin Amparo Posted May 20, 2013 Author Report Posted May 20, 2013 Thanks I'll check it out. And the 900 watts gives me room to grow later thanks 97 Lexus ES 300 Source: clarion cs702 Front stage: faital pro 6fe200, seas prestige 27tafnc/g Subs: soundqubed hds212 x2 Amp: mids and highs PPI P900.4. subs Alpine MRP-M850
Lifted2000Ford4x4 Posted May 20, 2013 Report Posted May 20, 2013 Thanks I'll check it out. And the 900 watts gives me room to grow later thanks yeah and its 1200rms at 1 ohm.
bighossf150 Posted May 20, 2013 Report Posted May 20, 2013 Save up and get a aq1200 Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
