Safely removing a system need help
Friday my car was rear ended and my trunk won't sit flush after prying it open my trunk is now 6" shorter ..it's been raining like crazy so I've had it covered with a tarp today been my first dry day and I started taking everything out..I'm a little nervous that I may have messed something up because after removing my 2 4channel amps I realized I forgot to take out the fuse I just removed the rcas then power then ground. I covered all the loose wires n rcas in electrical tape.anyways I have two runs of 0 gauge and 3 extra batteries in what order should I go about removing everything else .
Team CNGraphix
2013 sonata
Dc power 320 alt
3 kinetik 3 shuriken
All knue and sky high wiring
Dd m3b x2
Rockford 1000-4
2 fi sp4 18
4 vo 6.5
4 nendo pwx8
6soundqubed tweets
2 b1 tweets
Pioneer avh4500 hu
If it was minor, then yes.
For removing extra 1/0 runs and batts: remove positive connection at rear batts and tape of the ends. Then remove the connection at the front. The 1/0 is now dead. Remove ground wires with no worries.
SMD Super Seller
My Feedback Thread
Should be fine if they are wrapped good. I've done it with hot wires with 'in progress' builds.
And just to put it out there, ALWAYS connect rca's las when installing, and remove first when uninstalling.
SMD Super Seller
My Feedback Thread
  • Who's Online   0 Members, 0 Anonymous, 243 Guests (See full list)
