Need info on second battery hookup
Hey guys I am in need of help so I want to hook up a second battery so I can clean up my system. I have no clue on how to wire the second battery I've checked everywhere, and found so many different answers so I just finally broke down and came here to gain the knowledge. thanks everyone
you want to fuse the positive run though, before it gets to the second battery..
02 impala
VM-1
2 dc 12 xl's
RF t2500bdcp
Second skin damp pro
Kenwood head unit
240 mechman alt
d3400 in the front
d3100 in the rear
50ft Rockford fosgate ofc 1/0
Yes forgot to say that but fuse close to front battery and close to rear battery as well. Within a foot of each battery.
so can I ground the second battery to the body?
yes do it!!! i tested with and without that ground and gained 0.2 dbs on the meter and voltage drops went from 12.9 to 13.3 volts with that ;)
So this has my curiousity now.. I have runs for both pos and neg from front battery to back. Are you saying you gained by ditching the full ground run (front to back)? Or are you saying leave the full ground run and ADD a body/chassis ground from the rear battery as well?
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
Second option, leave the full ground from front to back and add the ground on the rear battery, i gained like 0.5 dbs and almost 1 volt IIRC on the voltage drop by adding the run from the front to the back, that`s on the SPL gains topic on the SPL room.
thank you guys so much I just have to upgrade my alternator, get some distribution blocks, 2 nice spools of 0 gauge so I can have plenty of wire left over for other bs, hook up my kinetic battery put the second box and amp in there and I should be good to go. ill be sure to post some updates and photos as far as the install if you all are interested.
  • Who's Online   0 Members, 0 Anonymous, 1881 Guests (See full list)
