12volt_Trini Posted May 23, 2013 Report Posted May 23, 2013 hey fellaz..... i have 2 v3`s tht need a box......the area tht i have is 15 inches height, 36 inches width and 25 inches depth....i kno they use maximum of 2 cubes and tht area is about 6 cubes.....the only plave i can really adjust is the depth.....ohhhh and it is foward facing in a toyota corolla wagon....what u guys think will be the best tuning freq.....im thinking 35hz.....it will be powered by a mtx 4001d throwing out just under 4ks....any help i would be grateful Regards Vehicle: 2000 Toyota Corolla Limited S Head Unit: DEX 99rs pioneer Speakers Sub treble/High mid : 2 1.4 inch throat 2080 18 sound drivers neodyium with wave guide Tweeters: 2 Mtx dome, 4 APT eminence super tweeters Mid Range: 2 18Sound 6" 6ND410 NEO,2 18 Sound 10" 10NDA610 NEO Low Mid Range: 2 18 Sound 10 NMB420 Sub: 2 Z-12 V.3 D1 - Sundown Audio Amplifiers Sub treble/High Mid: MTX Audio TA5302 Thunder Tweeters: JL Audio e4300 4-Channel Mid range: MTX Audio TC3002 Mid range: MTX Audio TA7402 Thunder 7402 Low Mid Range: MTX Audio TA7402 Thunder 7402 Sub: MTX Thunder Elite 4001D Alternator: 220amp mechman Batteries: 3 D3100 XS Power
Joe X Posted May 23, 2013 Report Posted May 23, 2013 Here is a suggestion 2xSundown Zv312 subs up/port back: Enclosure Specifications:Fb = 35 HzVb = 4 ft^3External Height = 15 inExternal Width = 36 inExternal Depth = 21.375 inPort Width = 4 5/8 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Top & Bottom (3 parts) = 36 x 21 3/8Left & Right Sides = 19 7/8 x 12 3/42x Front = 15 11/16 x 12 3/4Back = 36 x 12 3/4Shared Port Internal Assembly Parts:2 x Front to Back = 17 9/16 x 12 3/42 x Extension = 1 1/2 x 12 3/4 Assembly guide (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All boxes built outside the vehicle need to fit in their way in not just have the right dimensions.- The port needs 4 5/8" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested.
12volt_Trini Posted May 23, 2013 Author Report Posted May 23, 2013 the box in the diagram is upward facing?....would it make any difference if i put the subs infront with the port also i cannt use 16 inches for the height.....but i do have the depth would i be able to use the extra inch on the depth because i can use up to 26 inches in depth.....the width is fine....thanks any help is appreciated Vehicle: 2000 Toyota Corolla Limited S Head Unit: DEX 99rs pioneer Speakers Sub treble/High mid : 2 1.4 inch throat 2080 18 sound drivers neodyium with wave guide Tweeters: 2 Mtx dome, 4 APT eminence super tweeters Mid Range: 2 18Sound 6" 6ND410 NEO,2 18 Sound 10" 10NDA610 NEO Low Mid Range: 2 18 Sound 10 NMB420 Sub: 2 Z-12 V.3 D1 - Sundown Audio Amplifiers Sub treble/High Mid: MTX Audio TA5302 Thunder Tweeters: JL Audio e4300 4-Channel Mid range: MTX Audio TC3002 Mid range: MTX Audio TA7402 Thunder 7402 Low Mid Range: MTX Audio TA7402 Thunder 7402 Sub: MTX Thunder Elite 4001D Alternator: 220amp mechman Batteries: 3 D3100 XS Power
12volt_Trini Posted May 23, 2013 Author Report Posted May 23, 2013 i also noticed i will need to use a double baffle facing ? Vehicle: 2000 Toyota Corolla Limited S Head Unit: DEX 99rs pioneer Speakers Sub treble/High mid : 2 1.4 inch throat 2080 18 sound drivers neodyium with wave guide Tweeters: 2 Mtx dome, 4 APT eminence super tweeters Mid Range: 2 18Sound 6" 6ND410 NEO,2 18 Sound 10" 10NDA610 NEO Low Mid Range: 2 18 Sound 10 NMB420 Sub: 2 Z-12 V.3 D1 - Sundown Audio Amplifiers Sub treble/High Mid: MTX Audio TA5302 Thunder Tweeters: JL Audio e4300 4-Channel Mid range: MTX Audio TC3002 Mid range: MTX Audio TA7402 Thunder 7402 Low Mid Range: MTX Audio TA7402 Thunder 7402 Sub: MTX Thunder Elite 4001D Alternator: 220amp mechman Batteries: 3 D3100 XS Power
Joe X Posted May 23, 2013 Report Posted May 23, 2013 Changed the height using the extra inch of depth.
12volt_Trini Posted May 23, 2013 Author Report Posted May 23, 2013 ok great the port length remains the same?.....also the box will be complete double baffle?.....and could u give the measurements for the 45`s? Vehicle: 2000 Toyota Corolla Limited S Head Unit: DEX 99rs pioneer Speakers Sub treble/High mid : 2 1.4 inch throat 2080 18 sound drivers neodyium with wave guide Tweeters: 2 Mtx dome, 4 APT eminence super tweeters Mid Range: 2 18Sound 6" 6ND410 NEO,2 18 Sound 10" 10NDA610 NEO Low Mid Range: 2 18 Sound 10 NMB420 Sub: 2 Z-12 V.3 D1 - Sundown Audio Amplifiers Sub treble/High Mid: MTX Audio TA5302 Thunder Tweeters: JL Audio e4300 4-Channel Mid range: MTX Audio TC3002 Mid range: MTX Audio TA7402 Thunder 7402 Low Mid Range: MTX Audio TA7402 Thunder 7402 Sub: MTX Thunder Elite 4001D Alternator: 220amp mechman Batteries: 3 D3100 XS Power
12volt_Trini Posted May 24, 2013 Author Report Posted May 24, 2013 Could u plz provide the 45's for the port??.....i am not using the subs facing up....i am using them facing foward?....so my question is only the front is going to be double boarded....sorry to be a pest but i am new to building!!! Vehicle: 2000 Toyota Corolla Limited S Head Unit: DEX 99rs pioneer Speakers Sub treble/High mid : 2 1.4 inch throat 2080 18 sound drivers neodyium with wave guide Tweeters: 2 Mtx dome, 4 APT eminence super tweeters Mid Range: 2 18Sound 6" 6ND410 NEO,2 18 Sound 10" 10NDA610 NEO Low Mid Range: 2 18 Sound 10 NMB420 Sub: 2 Z-12 V.3 D1 - Sundown Audio Amplifiers Sub treble/High Mid: MTX Audio TA5302 Thunder Tweeters: JL Audio e4300 4-Channel Mid range: MTX Audio TC3002 Mid range: MTX Audio TA7402 Thunder 7402 Low Mid Range: MTX Audio TA7402 Thunder 7402 Sub: MTX Thunder Elite 4001D Alternator: 220amp mechman Batteries: 3 D3100 XS Power
Joe X Posted May 24, 2013 Report Posted May 24, 2013 The 45s are done in that type of box are done like this: Questions? let me know.
12volt_Trini Posted May 24, 2013 Author Report Posted May 24, 2013 u didnt edit the external cut out parts.....so instead of the cut out being 2 for the top....it will be one....right?....and the front which will be where the port is will be *2.....so it will be 4 cut out of 15 11/16*12 3/4....? Vehicle: 2000 Toyota Corolla Limited S Head Unit: DEX 99rs pioneer Speakers Sub treble/High mid : 2 1.4 inch throat 2080 18 sound drivers neodyium with wave guide Tweeters: 2 Mtx dome, 4 APT eminence super tweeters Mid Range: 2 18Sound 6" 6ND410 NEO,2 18 Sound 10" 10NDA610 NEO Low Mid Range: 2 18 Sound 10 NMB420 Sub: 2 Z-12 V.3 D1 - Sundown Audio Amplifiers Sub treble/High Mid: MTX Audio TA5302 Thunder Tweeters: JL Audio e4300 4-Channel Mid range: MTX Audio TC3002 Mid range: MTX Audio TA7402 Thunder 7402 Low Mid Range: MTX Audio TA7402 Thunder 7402 Sub: MTX Thunder Elite 4001D Alternator: 220amp mechman Batteries: 3 D3100 XS Power
Joe X Posted May 24, 2013 Report Posted May 24, 2013 u didnt edit the external cut out parts.....so instead of the cut out being 2 for the top....it will be one....right?....and the front which will be where the port is will be *2.....so it will be 4 cut out of 15 11/16*12 3/4....? Really not sure what all that means. I will say that if you are following the cutsheet above do follow it and do not change anything just cut the parts in the quantities shown and assemble them like in the pic, if you don't understand the cutsheet let someone help you or let someone build it for you. The box is made for subs up/port back to the rear gate, if you feel that you don't want to do it like that, dismiss what I posted and start a design of your own, here is a tutorial thread that was made for learning to calculate your own boxes: http://www.stevemeadedesigns.com/board/topic/145174-ported-box-design-a-tutorial-updated-630/page__hl__tutorial
