Hertz HX 300 Enclosure Help
Hi there I recently upgraded my subwoofer to a Hertz HX 300 sub and want to build the best box I can that will sound super clean but still get low enough as well. I want to go ported but I'm not sure what to tune it at, or how big to go? The manual says to make a box that is 1.35 cubes with a reflex tube tuned to 40 hz. I just think that is a little small to really be able to hit the lower frequencies. I was thinking about making a box that is around 2 cubes (before displacement) and tune it to 35 hz or so?? Just looking for a little help thanks.
Also I'm open to any ideas that you guys have, and what tuning frequencies you have your boxes at, thanks again.
So here is a suggestion:
Enclosure Specifications:
Fb = 35 Hz
Vb = 1.5 ft^3
External Height = 14 in
External Width = 28 in
External Depth = 13 in
Port Width = 2 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 25 1/4 x 12 1/2
Back = 28 x 12 1/2
Left & Right Sides:
Side 1 = 11 1/2 x 12 1/2
Side 2 = 12 1/4 x 12 1/2
Top & Bottom = 28 x 13
L Port Internal Assembly Parts:
Front to Back = 9 1/2 x 12 1/2
Extension = 18 x 12 1/2
Assembly guide (generic dimensions):
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
- All boxes built outside the car need to fit in their way in not just have the right dimensions.
- This box should be operated around subwoofer(s) rated power. If that´s not the case, let me know.
- The port needs 2" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
Those subs like smaller boxes from what I have read
2001 e 150 conversion van
kenwood kdc u942hd
lanzar opti 1900d
kicker zx 650.4
2 12" obsidians in a 33 hz box
4 set 6x9
2 8" mid woofers
2 almani tweets
200 amp alt
1750 oddesey front
2150 oddessy back
0 ga wire 8 ga sub wire
138,6 db
@ Joe X - WOW thanks for the actual design of the box that's awesome! Can't say thank you enough. So this box should hit the lows and maintain sound quality as well because that's what pretty much my whole system consists of. Also my amp doesn't have a subsonic filter because it's a five channel amp (audsion voce 5.1k to be exact) but its one of the cleanest sounding amp I've heard and it complements my Hertz HSK components perfectly (so this is why I went with the hertz sub as well)
@ reddude157 - 1.5 cubes is a pretty small enclosure I believe? have you heard/experienced what the optimum box size is for this sub? The reason I ask is because I would like to only have to build a box once. haha
Thanks again for all the input, every little bit helps.
This sub will peak if placed in larger standard 2 cube box, as above it will not be peaky but will have better extension than the 40+ tuned box, it's set to play the down to the upper 20s. Don't push too much power and you won't have any issues playing lower notes even if you lack a subsonic filter.
I'm going to be running 600 watts to it and that's its RMS rating, so everything should be good there. Also is that the final box volume after subtracting sub and port displacement?
  • Who's Online   1 Member, 0 Anonymous, 941 Guests (See full list)
