xxthugaxx Posted June 1, 2013 Report Posted June 1, 2013 i have a 86 Crown vic with a 5.0 and my alternator has a plug with 3 wires for the output.. so i want to know what can i do or to just buy differebt alternator with one cable...
Tarball Posted June 1, 2013 Report Posted June 1, 2013 The plug on your alt has nothing to do with the big 3. Big 3 = 3 wires 1. positive wire from alt output to batt pos 2. negative alternator case to frame/chassis ground (clean sanded metal) 3. negative frame/chassis ground to battery negative add those wire to what is already there. use 1/0 preferably ofc - cca is fine if that is what you have already. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Guest DC Power Kyle Posted June 2, 2013 Report Posted June 2, 2013 Actually tarball you're wrong. The two large wires on that plug are actually the output (B+). (Ford had the amazingly stupid idea to do this) OP, your stock alternator is a lost cause. You'll need to convert to a newer alternator and cut the wires and put ring terminals on it.
