Ran into a problem installing my coilovers. Need help ASAP
Upon trying to remove the wishbone from the front strut, the head of the bolt broke off. So I undid the castle nut on the upper control arm (with the pin) then the whole rotor came way down and I was able to get the strut out.
I had no problems getting the other side on, because I didn't have to undo the upper control arm.. But on this side, I cannot get it to line back up right. It's like the axle isn't going on a hole somewhere or something is just OFF. It's not like anything was bent, it just seemed to happen... The pictures and video should explain my problem a little better. What do I do ?
http://m.youtube.com/watch?v=H_cAAe8E7LQ
Did you take the whole shaft out? Like out of the trans? Or just the nut? Id pull it back apart.. at least pull that nut back off and make sure the shaft is all the way in the trans...edit.. I suck at reading lol.. ypu might of still pulled the shaft out of the trans...
1999 grand prix gt
kenwood x994 head unit
1/0 big 3 all shok industry single run to the back
New mid/highs coming not sure what
Soundqubed q2200d at .5 (have)
2 soundqubed hdc3 12s (have)
New box to be built.. sealed firing forward (yet to be designed)
200 amp alt not sure exact size or manufactor xs power batts
It's a 2000 Prelude, it's really weird. everythig still spins right. I can turn the rotor and see the shaft spin, and the rotor on the opposite side of the car spins in the opposite direction. So everything seems to be linked right.. But if you watch the video, you can see something just isn't right
