Box for 2 x 12 DC Level 2
Here is a suggestion, had to go deeper but I could go wider or taller if the box can't be that deep:
Enclosure Specifications:
Fb = 33 Hz
Vb = 2 ft^3
External Height = 13.5 in
External Width = 33 in
External Depth = 14.25 in
Port Width = 2 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 30 x 12
Back = 33 x 12
Left & Right Sides:
Side 1 = 12 3/4 x 12
Side 2 = 13 1/2 x 12
Top & Bottom = 33 x 14 1/4
L Port Internal Assembly Parts:
Front to Back = 10 1/2 x 12
Extension = 13 3/4 x 12
Assembly guide (generic dimensions):
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
- All boxes built outside the vehicle need to fit in their way in not just have the right dimensions.
- The port needs 3 1/2" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
Fb = 33 Hz
Vb = 3 ft^3
External Depth = 20.5 in
Port Width = 3 1/2 in
Cut Sheet List:
Front & Back = 33 x 13 1/2
Left & Right Sides = 19 x 12
Top & Bottom = 33 x 19
Shared Port Internal Assembly Parts:
2 x Front to Back = 17 1/4 x 12
2 x Extension = 6 1/8 x 12
Important notes:
Thanks!!!
Hate to ask this but could I get a schematic of 2 10s instead of 12? The box needs to be smaller so maybe 10's would work better.
So I changed it for a couple of L2 10, hope you can live withe new size.
beautiful, thanks. I do have a few questions
Left & Right Sides:
are different lengths?
Also is there a way to make the port in the middle like the 12' box?
Yes, there ia a 3/4" difference check the sketch to find out why, I would not recommend port in the middle for a small box like than when tuning low, it would need to take two turns each side and it therefore a loss of port efficiency, in addition to that, the box would need to be deeper due to all the extra parts needed to do the port.
ahh snap, I see it now. thanks for your help.
  • Who's Online   0 Members, 0 Anonymous, 5080 Guests (See full list)
