Caddy Eldorado Build Log
  • 4 weeks later...
Sold the BLs, so doing one 15" BTL for now. Original plans were 5 cubes @ 29hz, but thanks to me trusting home depot, it will end up 4.5cubes @ 31hz. This box is just something to have, no carpet or paint.
The home depot wood, that should all be 48" wide, but they like to make them different cuts :verymad:
Posted Image
All the wood cut..
Posted Image
Port Wall together...
Posted Image
Still waiting on a recone and basket if anyone at Fi every emails me back...but the BTL motor compared to a Sundown SD-1
Posted Image
Pics of it being built... BTW anyone that doesn't have clamps or access to a nail gun, I HIGHLY reccomend these screws, they countersink and predrill by them selves, can't ask for much for in a screw.
Posted Image
Posted Image
Posted Image
Posted Image
Not sure how you guys space your ports perfectly, but I just cut some small pieces the exact width of the port and place them in and screw the port.
Posted Image
Flush trim bits FTW...
Posted Image
Also another trick I use... I put on the back last so when I router everything out, all the saw dust falls right out, instead of having to vaccum it all out behind the port n ish.
Posted Image
Painting the port:
Posted Image
Posted Image
Box finished... just needs the sub!
Posted Image
Got bored today, so I ended up making an amp rack for both amps.
Old box out, nice lil mess back there lol.
Posted Image
Spare piece of 1/4" mdf I used for a amp rack in a Dodge Ram, turned out to be exactly perfect size, couldn't be an 1/8th more exact lol.
Posted Image
Base for the SAZ3000D
Posted Image
Posted Image
Posted Image
The 100.4 slides in attached to its bottom piece, I'm suprised this fit the first time around.
Posted Image
And where I left off for now, gunna make some trim pieces and still need the **** sub lol, and re-route some wires.
Posted Image
Posted Image
Yup, I will have a false floor, false wall, and side panels as well, basically in the end all you will see is that sexy motor =D. Vids will come soon enough, don't want to take any right now because I still need an alt.
I threw the box out the other day without even thinking, I willg et a pic of it when I build the next box. Anyways
Lil' more.... Yesterday I ripped EVERYTHING out. Rear deck getting re-done and doors getting wrapped. Also re-wired car, and I might finish the sound deadning and do the floor.
Anyways, part of the wiring done... Like I said this build is attention to detail! Speaker wires wrapped in techflex, each wire heatshrink and color coded, then labeled.
Posted Image
Posted Image
Posted Image
Gotta pick up some more tech flex.
