Caddy Eldorado Build Log
All speaker wire ready to go
Posted Image
Got the drivers side all wired up... fit 2 runs of speaker wire, 2 runs of 0 gauge, and 4 more wires for the alarm all in the stock wiring harness.
Posted Image
Posted Image
Also made it so you can not see and of the wire runs, except where they will need to be connected (0 gauge & fuse ran behind carpet, and same with speaker wires).
Posted Image
Other side wired up... everything hidden in factory wiring compartment...
Posted Image
Posted Image
Some wires flexed and heat shrunk..
Posted Image
Posted Image
Amp Rack done... front..
Posted Image
Back... 2 fans blowing directly on the heatsink for the saz3000, relay in center for remote turn on and fans
Posted Image
Amp Rack in..
Posted Image
lookin good potna. me personnally ( i did say me) I would have given that 3000d a lil bit more room ontop to breathe although you do have two fans. that's just me though.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
It's got about 1/2"... I would of gave it more room if I could... the box has to be lifted to clear the 100.4 already =(
I figured it's not a big deal since the heatshrinks are on the sides, not the top. Those fans keep blow some cold air too =D
New box for the Nightshade... a 6th order =D... thx to 80inches for the design!!
Posted Image
Posted Image
Posted Image
Thinking about doing a light coat of black and then putting grill cloth over so it just looks like a wall.
