gibblegeibel Posted June 3, 2013 Report Share Posted June 3, 2013 i was wondering what is the most power some one has ever put on one of these subs? i know they are rated for 600 watts rms. but what have you guys put to these subs/ Link to comment Share on other sites More sharing options...
CleanSierra Posted June 3, 2013 Report Share Posted June 3, 2013 Why are you curious? These questions intrigue me as to why people ask. At the end of the day, it's still ONLY a 2.5" coil, it has its limits. I'd guess that someone has probably sent 2K to one for burps, maybe more. Daily I'd bet the most you'll be able to send would be 1K to 1200W Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
gibblegeibel Posted June 3, 2013 Author Report Share Posted June 3, 2013 because i am getting a hifonics brz 2100.1 and i would if it would be ok to wire a set of vvx 10's to 1 ohm. the reason i asked so late is because i just thought about it. Link to comment Share on other sites More sharing options...
CleanSierra Posted June 3, 2013 Report Share Posted June 3, 2013 That amp should be fine for 2. You likely won't see full power out of it so on its BEST day it's putting out 1000W per sub. I built a box for a member on here that ran a BRZ1700 to each( but only at 2 ohms) and they were set with a DD1. He has not had any issues with them. That amp at 2 ohms it's rated at 1200W, so it'd think you'll be fine with the gains on your 2100 properly set. Box design will need to be good as well Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
gibblegeibel Posted June 3, 2013 Author Report Share Posted June 3, 2013 ok did you design the box as ported or sealed? then did you follow manufacture specs for the box Link to comment Share on other sites More sharing options...
CleanSierra Posted June 3, 2013 Report Share Posted June 3, 2013 I went on the low airspace side and braced the box with all thread. 2 front to back between the subs, and one the entire width of the box. And yes, it was ported tuned at 35Hz. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
CleanSierra Posted June 3, 2013 Report Share Posted June 3, 2013 I would have gone a little bigger, but he was in the trunk of a Mazda3. In hindsight, I would have given it more air by maybe half a cube. It gets violent though and he's been pleased with it I believe. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
gibblegeibel Posted June 3, 2013 Author Report Share Posted June 3, 2013 i have the single 12 in a 04 nissan sentra it is a 14 inches high, 16 deep and i think 31 wide. i was gana build the box for the vvx's to recomend specs for the ported box and tuning hz Link to comment Share on other sites More sharing options...
CleanSierra Posted June 3, 2013 Report Share Posted June 3, 2013 Recommended would be fine, you may shrink the internal airspace a little since you'll be overpowering them. You have plenty of space for 2 10" VVXs though. Don't they recommend 33Hz tuning? Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
gibblegeibel Posted June 3, 2013 Author Report Share Posted June 3, 2013 i am not sure i have to look. then how much smaller will i have to go on the internal space? could you give me a cut out sheet of what you think would work for size? Link to comment Share on other sites More sharing options...
