Peyton Cole Posted June 5, 2013 Report Posted June 5, 2013 I had a wreck few weeks ago and had to take my whole system out I been letting my 3 kinetik 1400s sit n my house on the hardwood floor I plan on charging them before putting them back in the car next week.. Can having a battery off of a power source for that long cause damage to them? Team CNGraphix 2013 sonata Dc power 320 alt 3 kinetik 3 shuriken All knue and sky high wiring Dd m3b x2 Rockford 1000-4 2 fi sp4 18 4 vo 6.5 4 nendo pwx8 6soundqubed tweets 2 b1 tweets Pioneer avh4500 hu
purplesyrup Posted June 5, 2013 Report Posted June 5, 2013 Keep them on a battery tender if possible. A couple weeks is not much much but I would be careful.
purplesyrup Posted June 5, 2013 Report Posted June 5, 2013 You can get a little agm battery tender at Harbor freight for cheap. All it needs to do is basically maintain your voltage.
Pioneerchuck Posted June 5, 2013 Report Posted June 5, 2013 You can get a little agm battery tender at Harbor freight for cheap. All it needs to do is basically maintain your voltage. Which of the chargers they have would you recommend? I saw they had a few and wasnt sure if you knew which one was AGM compatible or not. Need to find one before i go to the desert. :/
purplesyrup Posted June 5, 2013 Report Posted June 5, 2013 You can get a little agm battery tender at Harbor freight for cheap. All it needs to do is basically maintain your voltage.Which of the chargers they have would you recommend? I saw they had a few and wasnt sure if you knew which one was AGM compatible or not. Need to find one before i go to the desert. :/I run this and love it. http://m.oreillyauto.com/mt/www.oreillyauto.com/site/c/detail/SHU0/SC600A/N0360.oap?ck=Search_N0360_-1_4034&pt=N0360&ppt=C0005
purplesyrup Posted June 5, 2013 Report Posted June 5, 2013 Schumacher Electric - Hand-Held SpeedCharge Battery Charger model SC600a runs at 2 4 or 6 amp. It will maintain voltage for storage also its computer controlled. Has a built in fan and is 36.99. For agm
