BassDragon Posted June 5, 2013 Report Share Posted June 5, 2013 So I am getting ready to order two 10" Sundowns and I need a house for them, and I'd like it to be ported.My max dimensions are:Width - 36"Height - 14"Depth - 33"(Might want to look at this - http://i.imgur.com/WfZyCXb.jpg) And I'd like it to be tuned to 35hzI'll be using this amp to power them. Don't know what more I need to include. Thanks 1993 Toyota Tercel Two DC Audio Lvl 2 12'sDC 1.2k Link to comment Share on other sites More sharing options...
Lifted2000Ford4x4 Posted June 5, 2013 Report Share Posted June 5, 2013 include tuning frequency which you would like. Link to comment Share on other sites More sharing options...
Joe X Posted June 5, 2013 Report Share Posted June 5, 2013 Here is a suggestion: Enclosure Specifications:Fb = 34 HzVb = 2.45 ft^3External Height = 14 inExternal Width = 29 inExternal Depth = 18 inPort Width = 2 3/4 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:Front = 25 1/2 x 12 1/2Back = 29 x 12 1/2Left & Right Sides:Side 1 = 16 1/2 x 12 1/2Side 2 = 17 1/4 x 12 1/2Top & Bottom = 29 x 18L Port Internal Assembly Parts:Front to Back = 13 3/4 x 12 1/2Extension = 8 x 12 1/2 Assembly guide (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All boxes built outside the vehicle need to fit in their way in not just have the right dimensions.- This box should be operated around subwoofer(s) rated power. If that´s not the case, let me know.- The port needs 2 3/4" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested. Link to comment Share on other sites More sharing options...
BassDragon Posted June 6, 2013 Author Report Share Posted June 6, 2013 Thanks Joe. Now I just need to find out how much wood I need to get, and how much it'll run me. 1993 Toyota Tercel Two DC Audio Lvl 2 12'sDC 1.2k Link to comment Share on other sites More sharing options...
