That's better, that should be fine bud, might be a little bit much port area but since you are running on such low power I don't see it being an issue
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
Do you think those things could take 2000wrms? like a hifonics amp or something? they are 500w to 1000wrms and btw i do put my stuff in my moms SUV some times and run a wire from my house to the hatch but my parents just think im an asshole who listens to music because it shakes the house or else i would have it hooked up in there with a nice amp.
Which alpines are they? The type S or R's?
Also final impedance with the 2 subs together will be 2 ohms, so whatever hifonics amp you are looking at isn't going to put out 2000wrms at 2 ohms, it would be at 1 ohms that it could do that amount of power.
And if you want a flatter response out of that box and you are planning on hooking more power up to it later you might want to drop the port area down a bit, maybe between 14"-15".
Also double baffle on the front would be a good idea
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
alpine type r 12''s dual 2 ohm on each so if i wire each sub in parallel to 1 ohm than wire them together wouldent i get 1/2ohm final impedance?
2 ohm or half, but to run half an ohm you would need an amp capable of handling that low of an impedance, and the electrical power to back it up.
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
kk thanks for the help man
No problem
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
