Big 3 help please!
I have a 02 Grand am GT,i hvae 1400 watts total a 2 farad cap and 0awg front to back.Today i did some research and upgraded the big 3 to my knowladge,this is what i did.I ran all 0awg ,from alternator to battery with a inline fuse with 3-100 mini fuses in it in front of battery,then ran from my driver side strut tower to my negative on battery then thought i was taking a easy route wich i think is my prob and just grounded the engine from my alternator mounting bracket to my passenger strut tower,wich i read right before i did it that its fine to do that.I also used some brand new Gm side post battery adapters and i left all stock connections hooked up.i purchased everything from knukoncepts.com and also soldered everything together thanks to steve for that tutorial....anyways my cap reads the same as before but i swear it hits so much harder now, and my lights still dim at night wich was the main reason i did it.someone please help i wanna be able to listen to my music as loud as i want day or night without looking stupid with my lights flashing driving down the road..i forgot to mention i kept my stock battery in the car if that matters,I also grinded every connection to bare metal...Please help!
A additional battery is 100 times better than a cap. Sounds like you did a fine job with the wiring. I would suggest a AGM battery replacement for your old one. Then maybe a additional battery in the back.
I run about the same power with no dimming. Only one battery..but I have a H/O alternator.
battery>cap
i wouldn't fuse the positive from alt to battery unless you're using a unregulated alt. just my 2 cents
*Hummer H3*
HeadUnit
Pioneer AVH-X4600BT
Mids and Highs
8-CT Sounds Pro 8" 8ohm
4-CT Sounds Pro Tweeters
Amplifiers
1-CT Sounds 125.4
1-CT Sounds 60.4
1-CT Sounds 7000.1
Electrical
3-Runs of 1/0 CT Sounds
8-XS Power D3100
3-Iraggi 300 amp Alternators
Subwoofers
4-SQ Hdc3 15" Subwoofers
(Soon to be 4 15" Ct Sounds EXO)
  • Who's Online   0 Members, 0 Anonymous, 1433 Guests (See full list)
