*CAF* Duramax 2500 HD - Fiberglass Door Pods - Fiberglass Sub Box - PICS and HOW TO Videos Inside!
I'm definitely tuned in for this... I have been a fan of your YouTube channel for quite awhile now. I can tell you really put a lot of time into editing your videos.
keep it loud man :)
Thanks I am glad it shows! I really want to provide great videos where people can learn more about the advanced fabrication techniques. Keep it loud haha!
Love when speakers are rear mounted. Sex
Me too! You dont see them like this too often! Should turn out nice
TUNED IN
Thanks!
-Mark
Host of "CarAudioFabrication" - YouTube Car Audio Tutorial Channel
Check out my forum section here on SMD for my builds and tutorial videos!
Subscribe on YouTube: http://www.youtube.com/CarAudioFabrication
  • 4 weeks later...
Got to do some more work on this build:
In this post I will teach you how to reverse mount speakers and also how to use threaded inserts:
I found the threaded inserts at my local hardware store, I have also seen them at Home Depot, Lowes, and Menards. I really like them as you don't have to be concerned with stripping out the wood if you have to remove the screws to remove the speaker and put it back in. They are very easy to use as I will outline in the video at the bottom of the post:
Here is a picture of what they look like once mounted fully, I chose to use a washer as well to have more of a surface for the screw to hold against.
With the reverse mounting I found this configuration to be very appealing to the eye. I really like how you cant see any of the mounting holes, just the outer most part of the surround.
In the video below I outline how to install the threaded inserts, as well as how to reverse mount a speaker. Enjoy!
-Mark
Very clean work. I appreciate the tutorials as well. Keep up the good work.
Thank you, I am glad you like it. Thanks for posting!
-Mark
Here is step #4, forming the surface of the door pod. In this video I test out Steve's Sunflash resin.
http://youtu.be/XL3Mm7KAvls
-Mark
Anyone know the trick to getting the Youtube links to show like the previous posts, I tried a million times.
-Mark
  • Who's Online   1 Member, 0 Anonymous, 1918 Guests (See full list)
