ZDudas Posted June 17, 2013 Report Posted June 17, 2013 I have 2 Audioque SDC2.5 15's dual 4 ohm. Going to qire them up to a 4 ohm final impedance. It has direct connects instead of push terminals. I do I got about connecting them?
lolitskasey Posted June 17, 2013 Report Posted June 17, 2013 The easiest way i have found out to wire direct leads is to put some brass bolts in your box and just solder some wires on your direct leads to the inside bolts of your box pos to pos and neg to neg. Then wire your ohm load on the outside of the box, That way you aren't trying to solder 3 wires into one.
