99 Ford Ranger - Fi, Rockford, XS Power
So this is my build for my truck. Everything is in as of this moment and it slams. Check it out!!!!
Might as well show what was in the truck first.
^^Rockford T800-4 and 2 Kicker Comp 10's with RF T1's for Front-stage. Eventually laid box down so subs were forward and sounded a little better.
Now for the goods.
^^Boxes, boxes and boxes.
^^RF RCA's
^^Should be enough power.
^^Amps going in. T-1500bdCP and T400-4.
^^My 5 minute amp rack. LOL. New one already built and carpeted just got to get off my ass and put it in.
^^Mock up of doors.
^^Doors in and wired up. Now u may be asking where the other tweeter is or why I have the component set and a tweeter set. Ok here's the BS. The crossover that came with the T1 set, tweeter input and output is fried. Tweeter works fine but when run through crossover, no sound. I bought this set not long after they came out, I've already got my money's worth I think. So I bought the tweeter set and will run it on the front channel while the mids are on the rear. My new amp rack does not have a spot for the crossovers so I will be deleting them.
Now, MOAR pics.
^^Stinger Voltmeter. Probably wont but another one of these. Had to much bad luck with the numbers going out. I wanna try SMD's voltmeter in my Charger.
^^Mustang Dome Light.
^^Pioneer HU
Alright, on to the box build. Running 1 Fi BL 12, brand new style. In 2.5 cubes after all displacement at 31-32 hz.
^^Test fitting my cuts.
^^All done. What ya think?
On to the electrical part.
^^Fuse holders, heat shrink, ring terminals etc. some of this is for my Dodge.
2001 Oldsmobile Alero 4Dr GL2 - R.I.P.2006 Dodge Charger R/TJVC KDx40AudioQ 2200d
Big 3 and KNU 1/0
Fi BL 15" (09 model) 4.2 cuft net @ 33hz(15.8 sq in per cube)
1999 Ford Ranger XLTPioneer DEH-6200btRockford Fosgate T400-4, T1500-1bdCP, T1 6.5" Components, RCA's, Distro blocks.1 Fi Car Audio BL 12 - 2.5 cuft net @31hz(16.8 sq in per cube)XS Power S3400, 2 KNU 1/0 runs and KNU Big 3.
Build Log ----> http://www.stevemeadedesigns.com/board/topic/170878-99-ford-ranger-fi-rockford-xs-power/
^^Speaker wires, SHCA and Knu. Subwoofer and door speakers respectively. The Sky High wire will also be installed when I get off my lazy ass and put in the carpeted amp rack.
^^Knu 1/0
^^XS Power S3400 and modified battery tray.
^^Big 3.
^^Alternator run. Fuse holder is on a bracket. It's not just laying there.
^^CEAuto Electric Supply and KNU ninja shot.
^^Batt terminals. Yes I know they are backwards.
^^Sky High Car Audio, Knu and Big 3.
^^I have a 1/0 + and - run to under the seat to these distr blocks. Again Knu 4 awg.
Big 3 and KNU 1/0
Now here's what it makes worth the while.
^^Fi FTMFW!!!!!
^^Carbon Fiber Dust Cap
^^Size Comparison
^^All wired and ready to go. I was so damn excited I forgot to take a pic of the bottom of the magnet where the Fi sticker is. I have an older BL but it doesn't have the sticker. Damn.....FML.
^^ And BAM. There ya go. Stuffed in there and can still sit comfortably. Only other plans are to carpet box and put in my amp rack. May add a battery under the seat.
^^ And a pic of the truck.
Let me know what you guys think.
-Chipmunk
Big 3 and KNU 1/0
Nice job looks nice, love the choice of equipment!
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
What motor is that? 2.3? 4.0?
Vulcan 3.0
Big 3 and KNU 1/0
