PeteSiebenand Posted June 23, 2013 Report Posted June 23, 2013 ok so ive got an alpine Type X http://www.alpine.com.au/showItem.php?item_id=102 it will run at 2 or 4 ohms. i have a kenwood KAC 9401-D amp. Maximum power output (4Ω) 1800W x 1 Rated power output (4Ω, 14,4V) 500W x 2 (20Hz ~ 200Hz, 0.5%THD) Rated power output (2Ω, 14,4V) 900W x 1 (100Hz, 1.1%THD) Rated power output (1Ω, 14,4V) 900W x 1 (100Hz, 1%THD) Rated power output (CEA-2006) 500Watts RMS x 1 at 4 ohms and 1% THD power outputs below. how should i wire it?! drop the sub to 2ohms or run it at 4ohms?! http://www.kenwood-electronics.co.uk/products/car/amplifiers/KAC-9104D/details/
Jessica Posted June 23, 2013 Report Posted June 23, 2013 That is a mono amp. It has one channel not 2. It's 500X1 @ 4ohm and 900X1 at 1ohm and 2ohm What coils do you have on your subs, are the 2ohm coils, 4ohm coils? Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Jessica Posted June 23, 2013 Report Posted June 23, 2013 Never mind, i see you have the 1243D, so its dual 4ohm. So wire all the positives together to the amp +, and all the negatives to the amp negative,. in other words, wire it in parallel. I'll try to find a diagram if i can. edit: like this http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/1DVC_4-ohm_mono.jpg Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
TeamHT Posted June 23, 2013 Report Posted June 23, 2013 I don't know how he's going to get to run at either 2 or 4 ohms...unless he means he can buy either the D2 or the D4 but it sounds like he's already got it... Tell me...does this smell like chloroform to you?
Jessica Posted June 23, 2013 Report Posted June 23, 2013 He should just wire to 2ohm, he has one d4 sub. If he wants he can get a second and wire down to 1ohm. The 9105d will handle 1ohm fine. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
PeteSiebenand Posted June 23, 2013 Author Report Posted June 23, 2013 He should just wire to 2ohm, he has one d4 sub. If he wants he can get a second and wire down to 1ohm. The 9105d will handle 1ohm fine. 1 type X will be enough, i need to get my mids and highs in check. so we thinks run the DVC sub to 2ohms on the amp. cheers lads
