Mjbuley Posted June 24, 2013 Report Posted June 24, 2013 I am having trouble trying to find box deminsions for my Fi SSD 15. I am going to be putting it in the trunk of my 2002 Honda accord. I would greatly appreciate any assistance. it says I need around 3 or 4 cubic feet of space. im planning to make this a slot ported box. as far as fitting in the trunk the biggest size I can have is: Length (front to back) 20in Width (left to right) 30In Height (top to Bottom) 15.5in. I am also using 3/4in MDF. Any assistance to helping me find proper demensions would be greatly appreciated.. thanks!
Joe X Posted June 24, 2013 Report Posted June 24, 2013 Here is a suggestion, port/sub front, bear in mind you will probably need to build inside: Enclosure Specifications:Fb = 33 HzVb = 3 ft^3External Height = 15.625 inExternal Width = 30 inExternal Depth = 20 inPort Width = 3 3/8 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Front & Back (3 parts) = 30 x 15 5/8Left & Right Sides = 17 3/4 x 14 1/8Top & Bottom = 30 x 17 3/4L Port Internal Assembly Parts:Front to Back = 14 3/8 x 14 1/8Extension = 12 x 14 1/8 Assembly guide (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All boxes built outside the vehicle need to fit in their way in not just have the right dimensions.- This box should be operated around subwoofer(s) rated power. If that´s not the case, let me know.- The port needs 3 3/8" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested.
