F/s.... American Bass Xd2000
well since my other stuff aint selling i have to put this up for sale ...... would anyone be interested in a xd2000? its in great shape and works 100% .... very solid amp..
........SOLD........
.........no trades, unless some of my other items sell...sorry......
specs are..
Factory ratings:
1 x 500 Watts @ 4 ohms
1 x 1700 Watts @ 2 ohms
1 x 2200 Watts @ 1 ohm
Fuse: 4 x 40A
dont have refs over here yet, but heres my ROE feedback......
http://www.realmofexcursion.com/forum/showthread.php?t=41262
Thanks for looking......
__________________
Edited by bangin_explorer
ROE Ref's-
Pornstar, Peas247, Speedcult, 98Tahoe,
2k1 sdime, 20blackls00, acidboy, t00sh0rt
KICKERASSMAN, TheDukey42, RapidFire89,
bass-aholic, xhilr8n , GavRiley2007, Jalat,
checkmate kstms, kingscratchie, F3RR3T,
Audiobahnfreak, + more...
SMD Ref's-
Chode69, kingsuv, pstone11, *1LOWSUV*, kbreudi, RatBass1998,
Applejack, jonathancullen89, Audioman21, Derrick824,
96saturnsl, Caps, spl explorer, littleitaly1990, tudski, sebXC,
mbdblue, j_black10, tre4chevyryda, zfrerichs...
CAC Ref's-
forceww, alex95sl2, canyouhearmatt, flores210, Anime Freak,
iamtheone, dcmcki, rcpease, jigga jatt, mytyeerinpie...
THAT IS TRUE SUB PORN...got some sexy movement and a squirter spewsmiley.gif
Subs are like titties, They need to come in pairs because ones and threes are just wrong, and larger amounts will always draw a crowd, we all have our favorite sizes, but the bigger ones are more fun to watch move. :D
xd anyone???
ROE Ref's-
SMD Ref's-
CAC Ref's-
Here's a bump for you but I was curious it says 4 40amp fuses, there is a site I had to use the amps to calculate the power it should put out. Is it correct that 160 amps is worth 1000rms? Is there internal fusing?
thanks for the bump.... no internal fusings , and i believe those ratings are @ 14.4v.....
and im not positive what 160amps is worth wattage wise... im just going from specs.........
ROE Ref's-
SMD Ref's-
CAC Ref's-
here is more ratings i found... from ampguts.....
Factory ratings:
UsaCi ratings at 14.4V:
1 x 372.5 watts at 4 ohms
1 x 935.8 watts at 1 ohm
Fuse: 4 x 40A
from americanbassusa.com......
XD-2000 Amplifier Specifications:
Power Output @ DC 14.4V:
RMS @ 4 Ohm: 500W x 1 Ch.
RMS @ 2 Ohm: 900W x 1 Ch.
RMS @ 1 Ohm: 1800W x 1 Ch.
RMS @ 1 Ohm: 3000W x 1 Ch.
Signal to Noise Ratio: >100dB
THD (IHF-A): 0.2%
Input Sensitivity: 0.15V – 5V
Input Impedance: 47KOhm
Slew Rate: 10V/USec
Damping Factor: 300 @ 4 Ohm
Fuse Rating: 40A x 4
Dimensions (in mm):
Width: 240mm
Height: 61mm
Length: 470mm
Features
# MOSFET Power Supply Amplifier.
# Double Sided Through Hole Epoxy PCB.
# Gold-plated Brass Set Screw Terminals.
# 24dB/Oct. Crossover - Variable Low Pass Crossover (40Hz ~ 200Hz)
# Variable 24dB/Oct. Subsonic Filter 10Hz ~ 70Hz
# Variable Phase Shift
# 5 Way Protections
# Daisy Chain Through Output RCA
# Bass Remote Control
# Power/Protection LED
# 1 Ohm Stable Circuits
# Soft Start/Output Relay
# 18V Operation
# Parallel Operation
theres some different ratings but american bass is american bass... built solid...
ROE Ref's-
SMD Ref's-
CAC Ref's-
tTt.........
ROE Ref's-
SMD Ref's-
CAC Ref's-
tTt.............
ROE Ref's-
SMD Ref's-
CAC Ref's-
birthday bump..... someone make it a happy birthday.......
ROE Ref's-
SMD Ref's-
CAC Ref's-
ROE Ref's-
SMD Ref's-
CAC Ref's-
2/21 only............ 300.00 shipped + paypal....... make it a happy birthday... price goes back up after tonite.......
ROE Ref's-
SMD Ref's-
CAC Ref's-
  • Who's Online   0 Members, 0 Anonymous, 1363 Guests (See full list)
