AB XFL 15 box
walwalka
I'm purchasing a AB XFL 15 and I need to build a box for it. I'm looking to tune the bax to 32 hz and fit in the trunk of a honda civic. I need help with the box plans.
My trunk opening is:
18in tall by 35in wide
Once in the trunk there is:
19in tall
36in wide Between the rails of the lid. But the rails don't stick down that far.
30in deep(a little more, but this is safe.)
I would like the sub and the port to face the same direction, as I plan to fire it into the cable and seal it off.
There is the trunk for reference:
Thanks guys!
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
So here is a suggestion based on the power amp on your sig:
Enclosure Specifications:
Fb = 32 Hz
Vb = 3.8 ft^3
External Height = 16.5 in
External Width = 34 in
External Depth = 20.375 in
Port Width = 3 3/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 34 x 16 1/2
Left & Right Sides = 18 1/8 x 15
Top & Bottom = 34 x 18 1/8
L Port Internal Assembly Parts:
Front to Back = 14 3/8 x 15
Extension = 10 5/8 x 15
Assembly guide (generic dimensions):
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
- All boxes built outside the vehicle need to fit in their way in not just have the right dimensions.
- The port needs 3 1/2" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
Much appreciated! Thank you!
However... It's just not gonna fit in that config, unless I build it in the trunk. I'd like to be able to remove it if need be. Being 18 in tall just didn't give it enough room to slide in. I built a template out of cardboard..
I'm open to suggestion now, is there a different box config that would allow me to be able to slide it in?
If I decided that I wanted to build it in the trunk, What's the best way to go about that?
Thanks again guys!
In the end if I can't get the config I want I may have to decide on two 12's..
Awesome! Thanks again!
I built myself another cardboard template, we will see here shortly if it will fit.
It fits perfectly! Thanks a bunch!
I still wish you luck cause that's going to be a big heavy pig to get in and out , hehe.
Haha.. I know...... I won't take it out often, but I want to be able to take it out say I'm getting a new car or something a long those lines. I just don't want to be stuck with having to break the box to get it out.
  • 2 years later...
So I plan on getting an AB XFL 1522 and I cannot fine anything about what Cubic ft. for the box or anything. Could someone help me out designing a box for it?
  • Who's Online   0 Members, 0 Anonymous, 10808 Guests (See full list)
