1v1orgtfo Posted June 26, 2013 Report Posted June 26, 2013 Okay so im helping my friend make a box for his SWR-10d4 Alpine Type R 10" subwooferhe will be pushing 1000watts @ 2 ohms off his Kicker DX 1000.1he needs a PORTED box that is going to be 1.1 Ft3 (preferably slotted port(s))hes looking for something that will hit the lows and feel the bass, so I want to know the best place to put the box and what dimensions we should make it. were putting it in his 2006 350Z Coupe 2D He wants it pointed upwards infront of the hatch bar, kind of like this box but only one chamber instead of two. : http://www.ebay.com/itm/NISSAN-350Z-COUPE-03-08-DUAL-10-HATCH-CUSTOM-FIT-SUBWOOFER-ENCLOSURE-SUB-BOX-/390608882620 Im not sure if that would be the best spot for the sub, so any info would help, thanks.
1v1orgtfo Posted June 26, 2013 Author Report Posted June 26, 2013 I also just found this box on ebay http://www.ebay.com/itm/Nissan-350Z-Ported-Vented-Sub-Box-Subwoofer-Enclosure-1-12-Tuned-To-32hz-/321020418315?pt=Car_Audio_Video&hash=item4abe4ed90b&vxp=mtr and this box on sonic..this box is the perfect cubic feet but he wants something that will fit better in the 350z http://www.sonicelectronix.com/item_62682_Ground-Shaker-SQP-1-10.html it says that the size of the box can be reduced upon request. so would it be a good idea to get this box in 1.1 cubic feet or should we make one with a different kind of port?
john253a Posted June 26, 2013 Report Posted June 26, 2013 Most prefab boxes are in the 38-45hz So most won't hit them lows, To do that you'll need to build your own or get some to build you one Are you able to build or have someone build Or are you only interested in buying If your looking at pre fab idd suggest sealed If not post some measurement and see what arrives
1v1orgtfo Posted June 27, 2013 Author Report Posted June 27, 2013 He is going to put it under the strut bar to make things easier He wants to build the best box possible for his subs to hit the low bass notes the best. I can build the box for him so were going to go ported the dims to fit it under the strut bar are 20"W 12"H 16"D (If it can be a little shorter than 12" high that would be better because 12" is really pushin it)
