Battery Under the Hood
I was able to get one call out to XS Power, they suggested the D1200 being enough for what I would like to run.
What do you think?
I think the Deka is still better, I am just trying to get the best possible overall option.
XS Power D1200: 725CCA, 80RC, 44Ah, 33 pounds.
Deka Intim. 9A35: 680CCA, 100RC, 50Ah, 38 pounds.
I'm not worried about about weight between the Deka and the XS.
But each has an advantage, the Deka has more power and is cheaper but the XS is lighter and will be easier to install my system.
Tough choices...lol
You guys have said both batteries are good, which helps a lot!
Only thing you'd need for the XS is the ibar if your car is side post(assuming deka is top post) or you just want additional connection points. It will be cheap if you get it & the battery from Mechman or XS Power here on the forums. I got mine from mechman here with the ibar & extended battery posts & was much cheaper than sonic was.. Either one will be easy to use with your system just depends on what you need to connect it.
  • Who's Online   0 Members, 0 Anonymous, 938 Guests (See full list)
