box for 3 obsidian 12s
Dispensa
hey, would like a box designed for 3 obsidians 12s i am going to be running off an AQ2200 at a final impedance of 1.3 ohms
these are the max dimensions I am working with
36W x 15H x 28L
The trunk opening is 17 inches.
I have to be able to slide the box in, not able to build it inside the trunk, but I also want the most airspace possible
here is the info on obsidian 12s
Obsidian 12" v2 D2:
Re: 4.0 Ohm
Fs: 33 Hz
Qms: 5.21
Qes: 0.56
Qts: 0.51
Vas: 34.4
Le: 4.36 mH
BL: 19.1
SPL: 85.4 dB
Sd: 490 cm^2
Mms: 243.1 g
Xmax: 20mm
Peak-to-peak: 62mm (2.45")
Power Handling: 600 watts RMS
Recommended enclosure info:
Sealed ~ 1.0 to 1.5 ft^3
Ported ~ 1.75 to 2 ft^3 @ 30 to 35 Hz
Cutout: 11.10"
OD: 12.5"
Mounting depth: 6.75"
Mounting flange to top of surround: 1.25"
Displacement: 0.16 ft^3
I am aiming for low tuning
Thank you
  • Who's Online   0 Members, 0 Anonymous, 1703 Guests (See full list)
